Struts modding for an Anglia.
Old Apr 24, 2018 | 02:33 PM
carsmutley's Avatar
carsmutley
Zanglia
Default Struts modding for an Anglia.
just about to start building a pair of front struts for my boys 105e. Was gonna shorten the bodies to accept 2 litre Capri inserts (struts im using are from a Ford Classic Capri )and convert to 2 1/4" adjustable platforms. Just wondering if anybody has tried a different approach before ? I could cut the tubes right out of the uprights and replace the whole tube with one from say a Fiesta or mk4 Escort etc etc and then simply add the 2 1/4" kit to them . This would allow me to use the cheaply available shock inserts. Just wondering if anyone has ever compared the the tube diameters of classic ford struts to more modern ford strut tube diameters ? If the tubes are the right size i could do a conversion for much less money . Im a qualified welder so am more than capable of welding the new tubes to the hubs......anyone got any info ? or looked into it before. ? Thanks in Advance Gary
Old May 8, 2018 | 10:16 PM
pete241's Avatar
pete241
Same set up here,mk1 Escort racing. I got Koni in Oxsford 07759438510,just a touch machining top side and got a adjustable insert,+ all ready platform for 2 1/4 springs.
Well good on 350lbs springs,lapping Brans 48.1 indy....250 lbs 21/4 Koni on rear 1050kgs weight.Plenty caster you need !!
Oranoco
Sep 29, 2004 09:53 PM
BlueSmoke
Aug 17, 2004 04:31 AM
Thrush
14
Aug 8, 2004 01:16 PM
MadMac
11
Jun 23, 2004 01:07 PM
Nov 5, 2003 07:03 PM
