10 spline clutch for tko to cosworth
Old Apr 16, 2018 | 07:35 PM
james kiely's Avatar
james kiely
Default 10 spline clutch for tko to cosworth
just having a look about my tko600 tonight and i noticed it is 10 spline on the spigot shaft.
should i change over to a 23 splineshaft or just use a 10 spline clutch ?
anyone able to recommend one to me please
thanks in advance
Old Apr 17, 2018 | 06:01 AM
The Youth.'s Avatar
The Youth.
Reyland had these clutch plates
Steve
Old Apr 17, 2018 | 06:10 AM
james kiely
thanks mate
Old Apr 17, 2018 | 10:47 AM
stevieturbo's Avatar
stevieturbo
C**t
Helix or any clutch supplier should be able to sort you a disc in any spline really.
Just tell them diameter and thickness required, and material/application.
Old Apr 17, 2018 | 09:47 PM
james kiely
cheers stevie.
what would you expect to pay for a disc mate?
Old Apr 17, 2018 | 10:39 PM
stevieturbo
C**t
It's just a clutch disc
http://www.helix-autosport.com/produ...poke-products/
Price will depend on the type of disc you want etc.
But you'd need to find out exactly what size you need, thickness, material etc to suit your input spline.
Some BMW's run a 10 spline, and lots seem to be 240mm diameter, same as a Cossie. But whether that spline diameter is the same as yours I dont know. Googling would suggest BMW might be a little larger.
The US Ford clutches that would use that spline all seem to be larger diameter maybe around 265mm ( 10.5" )
So really a clutch disc could be as cheap as any generic OEM replacement disc or a lot more for something fancier. Just depends what you need.
Old Apr 19, 2018 | 02:12 PM
Caddyshack's Avatar
Caddyshack
Steve
Yup, Ł289 at Reyland, no messing around:
Cosworth 2wd With Tremec TKO Clutch Plate
Srung paddle clutch plate with the correct spline for use with Tremec TKO600 gearbox conversions using your original or uprated clutch cover. Ok for upto 375hp with a standard cover or in excess of 550hp when used in conjunction with our uprated cover. 5 or 6 paddle available.
240mm diameter (same as std Cosworth)
Works fine with standard or uprated clutch cover
Ł289*
Old Apr 19, 2018 | 05:25 PM
stevieturbo
C**t
Crikey..sounds like a lot.
Give Helix or TTV a shout ?
What diameter is your input shaft ?
Old Apr 19, 2018 | 05:28 PM
Caddyshack's Avatar
Caddyshack
Reyland need a profit in the product but, of course, if you can solve it cheaper without getting it wrong then go direct.
Old Apr 19, 2018 | 05:37 PM
stevieturbo
C**t
Absolutely, and it does depend on exact spec of disc.
Again, taking note that not all clutch discs are the same thickness....here is a simple off the shelf organic plate, 9.5" and 10 spline that should work.
https://www.jegs.com/i/Centerforce/183/281222/10002/-1
Old Apr 19, 2018 | 05:45 PM
stevieturbo
C**t
Or something you could adapt with suitable flywheel ?
https://www.ebay.com/itm/Tilton-7-25...1ajiPl&vxp=mtr
Old Apr 19, 2018 | 07:17 PM
Caddyshack's Avatar
Caddyshack
I did not know that...useful to know
Old Apr 19, 2018 | 09:48 PM
james kiely
thanks stevie and toby for your input
stevie you have some great knowledge of all this stuff ,fair play for sharing it
l0ubie
May 8, 2009 10:34 PM
MTZ1
Ford Escort RS Cosworth
Jan 22, 2009 07:00 AM
Badman38
May 17, 2008 08:54 AM
Ollie MK5 Turbo
Oct 18, 2006 12:57 PM
sunny
Aug 27, 2004 01:57 PM
