Zetec turbo sierra clutch/flywheel help
Got a zetec turbo in my sierra at the min running a 1.8 zetec flywheel redrilled for pinto clutch, tbh is holding okay ish but am starting to get some slip. I am going to be running a rx8 box with adaptor plate any ideas what setup i can upgrade too ??
What sort of power are you at ?
I ask as I am thinking of upgrading before I start. A fellow builder has fitted the 240mm mk1 focus Rs Ap clutch he is running the Mt75 gearbox and it was running 325 ish
i've got a cossie 4 paddle in mine with the frs cover plate using a normal 2.0 flywheel machined to give better clamping load. no idea how it works yet, hope to find out soon though!
But have you been getting away with 260 on the t9 ?
I have an rx8 5 speed but I don’t want to mess about with an hydraulic clutch conversion and an engine swap this year.
Antony.
Ford Classics & Vintage
Nov 11, 2012 10:20 PM
mrviper
11
Jan 17, 2006 01:32 AM
Red16
Escort MK 5 / MK 6
Aug 8, 2005 09:18 PM
