Antiroll bar polly bush Query
Just a Query about how you guys go about fitting these to the rear of a mk2 escort, Originals have cuts in them to slide over the bar for easy wrap round installation but the poly bush ones are solid , Do you guys cut a slot in the new polybush and wrap around bar and let the clamp hold the bush. or do you strip the whole lot down and slide it over the end making more hassle .. opinions please ,..
thanks guys x2 different opinions , i was wondering if cutting the bush it would loose its rigidness overtime but if folk have cut the bush and not had problems then it would be simpler, but if it effected the bush then i would have went for taking an end of the bar and sliding both into place
EssexMikeSi
Jul 6, 2012 09:01 AM
cossy fiesta
May 7, 2012 11:00 PM
Westy
50
Jan 19, 2005 05:45 PM
