Loctite 518???
The Cosworth workshop manual says use the loctite 518 on the throttle cable bracket to plenum bolts! & air temp sensor! I’ve used as a flange sealant gasket but never on threads, is there a reason for this? What do you guys use?
I guess a dab of sealer on the bracket threads won't hurt just help seal threads.
I would say it's for the stud than the bolt so it don't unwind when u remove bracket.
Cheers Paul I did mean the studs that go through the plenum, i couldn’t see why 518 was recommended surely thread loc n seal would do! (Not on the air temp sensor)
What would you use on the nylon spigots? Was thinking PTFE would be ok?
Prince John
Jul 17, 2017 08:18 AM
Ginge !
Jun 5, 2005 11:02 AM
