Zetec turbo with jenvey inlet manifold
Old Mar 30, 2018 | 12:31 AM
fitzpodge's Avatar
fitzpodge
Podge
Default Zetec turbo with jenvey inlet manifold
Hi all
i am in the middle of a 2.0L blacktop zetec turbo build. PEC rods and pistons. T3 turbo and run by omex 600.
I am wondering if there will be much of a difference between using the RST EFI inlet manifold which i already have or to use a Jenvey intake manifold ( costs about AUD$3500 ) ?
i am upgrading my BC gearbox also with a Quaife LSD and full rebuild.
Do you think 300 hp is too much fpr that box ?
Is it over kill having a gearbox like that and potentially way more HP available ??
TIA 👍
Old Mar 30, 2018 | 08:34 AM
zvh's Avatar
zvh
my mfi inlet manifold on my zvh is ok at 423bhp and and my stage 2 plus Bernie box is still fine at 423bhp too . as for the jenvey and zetec inlet I don't have a Scooby doo ?
Old Mar 30, 2018 | 08:56 AM
Caddyshack's Avatar
Caddyshack
I expect the jenvey would possibly give better throttle response and maybe better at high power but if you can get away with standard it might allow funds to be used elsewhere on the car.
I am considering the large roller barrel cossie one for my 2.2 stroker
Old Mar 30, 2018 | 10:25 AM
fitzpodge's Avatar
fitzpodge
Podge
ahh nice man, are you saying you have an RST BC gearbox aswel and running 400hp ? or are you running a different gearbox ?
Old Mar 30, 2018 | 02:46 PM
RUBY123's Avatar
RUBY123
they are massive dont know if it will fit unless you mount the engine correctly
Old Mar 31, 2018 | 08:56 AM
studabear's Avatar
studabear
My Zetec turbo chewed BC gearboxes. 1 lasted about 500 miles. Another lasted 3 years. After ending up in the hard shoulder of the motorway I decides to fit a Focus Rs gearbox.
Old May 12, 2018 | 07:08 AM
Karlos G's Avatar
Karlos G
Balls Deep!
The EFi inlet is awful, almost any other inlet flows better... You just have to look at the design/shape of it.
BC Box's will last as long as they last at that power, the Quaife will actually put more load on the poor little thing.
Old Jun 7, 2018 | 02:08 PM
zvh's Avatar
zvh
no i didnt say that but as your asking yes i am cts stage 2 bc type with cryno gear kit treatment and quaife diff works fine !! and as for the old bc type box ive had 16 rs turbos all on the road used daily the standard bc type box running at 286bhp upwards and 320 foot pound lasted 8 years or more with the standard ferguson viscous type diff so each to there own experience i say im not going to get in to a 20 page argument about gear boxes but a bit of mechanical sympathy dont go a miss , depends iff your running silly drive shaft angles , cheap comma gear oil , broken gearbox mounts etc etc the bc eventually stripps the teeth off 3 rd gear but hay ho it bolts straight on !
and due to where my turbo is mounted i couldnt run the mtx75 brackets .
and the 6 speed getrag box used in the st and the mini cooper s !
after 12 years at bmw parts i can tell you the mini cooper s box 6 speed getrag breaks fine at 167 bhp on a 1.6 mini cooper s .
over and out
Old Jun 7, 2018 | 05:56 PM
zetaboostboy522bhp's Avatar
zetaboostboy522bhp
I broke bc box twice in a week running zetec turbo 280 bhp 300lbs , both times stripped every tooth off the crown wheel and pinion, they were brand new ford items as well , second time it looked like they had been machined off they were that smooth lol. I drove like a twat thou. It was also fitted with a quaife diff.
Not bad really Ł500 in a week and a bag of bits
Cheers paul
Old Jun 7, 2018 | 06:55 PM
zvh's Avatar
zvh
Dont supprise me at all mate , ive done them myself on a high compression xr3i turbo in 30 mins 😂
but then ive had others last years , so hit or miss really and mine have allways been on road , not track cars . While its working i wont be fixing it i know that my car is at 411 foot pound of torque and touch wood the gearbox is ok so far , i am nice.to it in lower gears tho to be fair
Old Jun 7, 2018 | 10:27 PM
zvh's Avatar
zvh
Hi all
TIA 👍
potentially your t3 will be maxed out anyway at 330bhp !! So get a standard bc box 😉 go well with the chinese con rods i mean pec
Matt_fez
46
Jul 14, 2016 11:34 AM
AustenW
Ford Focus RS Parts for Sale.
Jun 28, 2016 12:33 PM
Naughty boy creations
Sep 6, 2013 07:18 PM
RUBY123
Jul 30, 2013 02:59 PM
marilyn
13
Jul 17, 2010 12:16 PM
