Supercharging my st150
£4k plus VAT is the starting price on the Jamsport Rotrex kit...they are REALLY good on supercharged stuff
I expect brakes would be needed and inform your insurance company.
The price will rise when you start doing things like exhaust etc.
nope - not unless you're after daft power figures. It would probably be cheaper for you to stick a td04 turbo kit on it.
again, this can be mapped using the standard ecu.
I've a number of friends who run turbo ST150's. One of them is selling a complete setup at the moment (turbo, manifold, exhaust, intercooler, clocks, ecu, etc.)
turbo kit - £1900 :
T3 Hybrid Turbo
Log Style Manifold
3" V Band Exhaust
Boost pipes with silicone hoses in green
Intercooler
Baileys DV
AEM Air Filter
Turbosmart Boost Controller
470CC Injectors
Map Sensor
Sump with AN fittings for oil return
Boost gauge
Ecu clocks etc mapped @ 274bhp 280lbft 11psi
engine - £1900 :
Wiseco Pistons 10.1:1CR
K1 Rods
Copper Headgasket to give 9.2:1CR
Mahle Motorsport Bearings
ARP Main Bolts, Head Bolts, Crank Bolt
Ford / Cosworth Timing Kit
High Pressure Oil Pump
New Water Pump
Cylinder Head Refreshed, Valves Reseated, New Stem Oil Seals
Head and Deck Skimmed
Head & Block Painted Silver
Genuine Ford Gaskets
2,500 mile since built including 1,000 mile running in.
he's keen to do a deal, and also has a cosworth inlet manifold for 500 quid.
If you're seriously interested, i can pass his contact details on to you.
You could build the kit yourself, but it would likely cost more.
T3 Hybrid Turbo
Log Style Manifold
3" V Band Exhaust
Intercooler
Baileys DV
AEM Air Filter
470CC Injectors
Map Sensor
Boost gauge
engine - £1900 :
K1 Rods
New Water Pump
turbo kit - £1900 :
T3 Hybrid Turbo
Log Style Manifold
3" V Band Exhaust
Intercooler
Baileys DV
AEM Air Filter
470CC Injectors
Map Sensor
Boost gauge
engine - £1900 :
K1 Rods
New Water Pump
T3 Hybrid Turbo
Log Style Manifold
3" V Band Exhaust
Intercooler
Baileys DV
AEM Air Filter
470CC Injectors
Map Sensor
Boost gauge
engine - £1900 :
K1 Rods
New Water Pump
thank you very much
Regards
