2wd & 4wd front fog lights
Old Feb 9, 2018 | 09:00 AM
tosh's Avatar
tosh
Question 2wd & 4wd front fog lights
Does anyone know if the fog light glass is bonded into the Aluminium casing?
Old Feb 9, 2018 | 05:44 PM
Mark V8's Avatar
Mark V8
Yes they are bonded, stick them in the oven for a while at around 80 degrees and they pull off no problem.
Old Feb 9, 2018 | 07:00 PM
tosh's Avatar
tosh
Cheers for that, I done it at lunch by just gently pushing and they came out easily, the lense came out clean just leaving the grey sealant bonded to the frame.
You dont happen to know what the grey sealant is by any chance Mark?
Old Feb 9, 2018 | 07:07 PM
Mark V8's Avatar
Mark V8
Sorry, I don't know.
Would have thought any polyurethane type of body sealant would do.
There is a Russian guy selling new glass cheap on ebay
https://www.ebay.co.uk/itm/FORD-SCOR...MAAOSwNnRYl4yj
Old Feb 9, 2018 | 07:15 PM
tosh's Avatar
tosh
Believe it or not they are still original 30-year-old lenses with not a mark on them, I’m just stripping them to refurbish them and get the reflectors re-plated.
thanks for the link though as it might be worth getting a spare set.
Old Feb 10, 2018 | 05:40 PM
dojj's Avatar
dojj
Resident Wrestling Legend
the biggest problem i found was that the bolts holding them into place would corrode as they were aluminium and strip the heads
Old Feb 10, 2018 | 05:51 PM
I repaired mine with tin foil. I cut pieces out and bonded them to the foglight housing.
Old Feb 10, 2018 | 06:37 PM
tosh's Avatar
tosh
I know what you mean dojj I had to drill one out! Why is it always the last bolt that gives you trouble.
Old Feb 10, 2018 | 06:48 PM
tosh's Avatar
tosh
Was thinking about that Glenn, was going to use some self adhesive tape that you use on ducting, inquired at a couple of online plating companies one came back with a quote to re-silver 4 of the rear reflectors for £288 and the other was £250
Found a local place yesterday that will do them for £40
Old May 26, 2021 | 09:10 PM
luke2020's Avatar
luke2020
Default re-silvering
where was the place that would re-silver them for £40 ?
was this using the vacuum metallising vapour deposition process ?
Gary Osborne
Jul 28, 2012 05:02 PM
Matt Baxter
Feb 11, 2010 05:17 PM
Paul_Painter
Dec 16, 2005 12:58 AM
rs cos
Mar 1, 2005 10:04 AM
