Transit cosworth rebuild project
Old Jan 28, 2018 | 01:41 AM
Frenchie72's Avatar
Frenchie72
Default Transit cosworth rebuild project
This transit use to be imperial blue then somebody decided to paint it black with orange stripes.
Ive replaced everything on the back end and beefed up all the brackets and hangers for the 5 link set up.
The rear axle is having a brake disc conversion this is being done by Mark at MK Motorsport AP four pot
calipers with also be fitted and a brake bias control .
There will also be a pair of six pot calipers fitted on the front I've also decided to make the front end all adjustable too.
Once the floor and arches are welded in I will then sort the front end out welding in adjustable turret tops.
The bottom arms will either be converted to rose joints or I might make a new pair tubular arms I haven't made
a decision yet so we will see.
I will be putting it back into imperial blue but that is a while off yet.
There will be another 3 recaro seats going in the rear these will sit over the rear turrets and brace.
I have also got all original ford panels to finish this off.
Attached Thumbnails Transit cosworth rebuild project-img_4396.jpg   Transit cosworth rebuild project-img_4400.jpg   Transit cosworth rebuild project-img_0965.jpg   Transit cosworth rebuild project-img_0938.jpg   Transit cosworth rebuild project-img_0963.jpg
Transit cosworth rebuild project-img_0964.jpg   Transit cosworth rebuild project-img_1006.jpg   Transit cosworth rebuild project-img_0915.jpg   Transit cosworth rebuild project-img_0918.jpg   Transit cosworth rebuild project-img_0917.jpg
Transit cosworth rebuild project-img_0966.jpg   Transit cosworth rebuild project-img_1004.jpg   Transit cosworth rebuild project-img_1229.png   Transit cosworth rebuild project-img_0929.jpg   Transit cosworth rebuild project-img_0928.jpg
Transit cosworth rebuild project-img_0948.png   Transit cosworth rebuild project-img_0969.jpg   Transit cosworth rebuild project-img_1002.jpg   Transit cosworth rebuild project-img_1003.jpg   Transit cosworth rebuild project-img_0934.jpg
Transit cosworth rebuild project-img_0935.jpg   Transit cosworth rebuild project-img_0936.jpg   Transit cosworth rebuild project-img_0937.jpg   Transit cosworth rebuild project-img_1007.jpg   Transit cosworth rebuild project-img_1008.jpg
Transit cosworth rebuild project-img_0925.jpg   Transit cosworth rebuild project-img_0950.png   Transit cosworth rebuild project-img_0999.jpg   Transit cosworth rebuild project-img_0997.jpg   Transit cosworth rebuild project-img_0995.jpg
Transit cosworth rebuild project-img_0993.jpg   Transit cosworth rebuild project-img_0994.jpg   Transit cosworth rebuild project-img_1001.jpg   Transit cosworth rebuild project-img_1024.jpg   Transit cosworth rebuild project-img_1022.jpg
Transit cosworth rebuild project-img_1026.jpg   Transit cosworth rebuild project-img_1027.jpg   Transit cosworth rebuild project-img_1030.jpg   Transit cosworth rebuild project-img_1031.jpg   Transit cosworth rebuild project-img_1746.jpg
Transit cosworth rebuild project-img_4021.jpg   Transit cosworth rebuild project-img_3876.jpg   Transit cosworth rebuild project-img_4022.jpg   Transit cosworth rebuild project-img_4023.jpg   Transit cosworth rebuild project-img_4024.jpg
Transit cosworth rebuild project-img_4020.jpg   Transit cosworth rebuild project-img_2053.jpg   Transit cosworth rebuild project-img_2054.jpg   Transit cosworth rebuild project-img_3661.jpg   Transit cosworth rebuild project-img_3662.jpg
Transit cosworth rebuild project-img_3663.jpg   Transit cosworth rebuild project-img_3664.jpg   Transit cosworth rebuild project-img_3665.jpg   Transit cosworth rebuild project-img_3666.jpg   Transit cosworth rebuild project-img_3668.jpg
Transit cosworth rebuild project-img_3669.jpg   Transit cosworth rebuild project-img_2055.jpg   Transit cosworth rebuild project-img_2056.jpg   Transit cosworth rebuild project-img_2057.jpg   Transit cosworth rebuild project-img_3674.jpg
Transit cosworth rebuild project-img_3679.jpg   Transit cosworth rebuild project-img_3680.jpg   Transit cosworth rebuild project-img_3681.jpg   Transit cosworth rebuild project-img_3682.jpg   Transit cosworth rebuild project-img_3683.jpg
Transit cosworth rebuild project-img_3684.jpg   Transit cosworth rebuild project-img_3685.jpg   Transit cosworth rebuild project-img_3686.jpg   Transit cosworth rebuild project-img_3687.jpg   Transit cosworth rebuild project-img_3690.jpg
Transit cosworth rebuild project-img_3691.jpg   Transit cosworth rebuild project-img_3692.jpg   Transit cosworth rebuild project-img_3693.jpg   Transit cosworth rebuild project-img_3706.jpg   Transit cosworth rebuild project-img_3707.jpg
Transit cosworth rebuild project-img_3708.jpg   Transit cosworth rebuild project-img_3709.jpg   Transit cosworth rebuild project-img_3710.jpg   Transit cosworth rebuild project-img_3711.jpg   Transit cosworth rebuild project-img_3712.jpg
Transit cosworth rebuild project-img_3713.jpg   Transit cosworth rebuild project-img_3732.jpg   Transit cosworth rebuild project-img_3733.jpg   Transit cosworth rebuild project-img_3734.jpg   Transit cosworth rebuild project-img_3737.jpg
Transit cosworth rebuild project-img_3768.jpg   Transit cosworth rebuild project-img_3769.jpg   Transit cosworth rebuild project-img_3770.jpg   Transit cosworth rebuild project-img_3781.jpg   Transit cosworth rebuild project-img_3782.jpg
Transit cosworth rebuild project-img_3783.jpg   Transit cosworth rebuild project-img_3784.jpg   Transit cosworth rebuild project-img_3785.jpg   Transit cosworth rebuild project-img_3787.jpg   Transit cosworth rebuild project-img_3788.jpg
Transit cosworth rebuild project-img_3789.jpg   Transit cosworth rebuild project-img_3825.jpg   Transit cosworth rebuild project-img_3826.jpg   Transit cosworth rebuild project-img_3827.jpg   Transit cosworth rebuild project-img_3828.jpg
Old Jan 28, 2018 | 08:03 AM
turbo m's Avatar
turbo m
Wasn"t this transit on the front cover of fast ford many moons ago?????
I do like it in imperial blue, keep the updates pics coming...
Old Jan 28, 2018 | 08:49 AM
Caddyshack's Avatar
Caddyshack
Love the van, that must confuse and shock a few people. I too like it in blue
Old Jan 28, 2018 | 10:31 AM
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
Cool project
Old Jan 28, 2018 | 01:34 PM
Cragrat's Avatar
Cragrat
sit boo boo sit
Always liked this van
As above back to blue
Old Jan 28, 2018 | 02:40 PM
jonfoc's Avatar
jonfoc
Great project but why 3 threads?
Old Jan 28, 2018 | 03:23 PM
Kyle Langford's Avatar
Kyle Langford
was Geoffs from chorley street garage, he built it and sold it on and got painted that hideous colour
Old Jan 28, 2018 | 05:15 PM
frenchie rs's Avatar
frenchie rs
Because he has got 2x left hands.
Old Jan 28, 2018 | 05:25 PM
jonfoc's Avatar
jonfoc
Thumbs down
Christ! Imagine how good your fabrication skills would be if you had a right hand too! Keep up the great work. I’d love a lairy van.
Old Jan 28, 2018 | 05:34 PM
frenchie rs
His work is great, really good eye for detail and considering how the van was when he got it. He has done some great work with rebuilding the back end. You could carry an Abrams tank on that now. But like he says a long way to go even with his two left hands.
Old Jan 28, 2018 | 05:53 PM
Shaun's's Avatar
Shaun's
Gotta love this van....but please re do blue..
Old Jan 28, 2018 | 05:55 PM
Mark Shead's Avatar
Mark Shead
Did you see the brake pads are in back to front on the picture of the disc being held in the vice.
Mark
Old Jan 28, 2018 | 05:58 PM
Caddyshack's Avatar
Caddyshack
Mark
That's alright, just drive home in reverse.
Old Jan 28, 2018 | 06:03 PM
Mark Shead's Avatar
Mark Shead
Lol not quite the discs run on the metal side and not the friction side.
Cool project though.
Mark
Old Jan 28, 2018 | 06:06 PM
Caddyshack's Avatar
Caddyshack
Mark
Oh, I didn't think totally wrong way around.
Old Jan 28, 2018 | 06:07 PM
Caddyshack's Avatar
Caddyshack
Mark
Just looked and I can see what you mean now
Old Jan 28, 2018 | 06:25 PM
PaulinhoT's Avatar
PaulinhoT
10 Year Member
Brilliant project
Old Jan 28, 2018 | 06:52 PM
st220kyle's Avatar
st220kyle
I can remember seeing this van in a magazine about 15+ years ago, good to see its still about, keep up the good work
Old Jan 28, 2018 | 07:10 PM
frenchie rs
He done that just to check the adaptor spacing. Old pictures though. Hopefully he will put some up of the new front set up he made with MK Motorsport.
Old Jan 28, 2018 | 07:16 PM
frenchie rs
He done that just to check the adaptor spacing. Old pictures though. Hopefully he will put some up of the new front set up he had made with MK Motorsport.
Old Jan 28, 2018 | 07:17 PM
jonfoc's Avatar
jonfoc
So what's the connection between frenchie rs and frenchie 72?
Old Jan 28, 2018 | 07:39 PM
Caddyshack's Avatar
Caddyshack
Keen to experiment with different types of Frenchie?
Old Jan 28, 2018 | 07:45 PM
jonfoc's Avatar
jonfoc
Weird!!!
Old Jan 29, 2018 | 01:13 PM
Frenchie72's Avatar
Frenchie72
Default Chassis and floor supports welding and fabrication
A lot of welding and fab work it will be worth it in the end.
the suspension turrets originally were welded to the floor when I started this I noticed the turrets were being
pushed outwards hence the reason I've gutted everything and starting again.
you will see in pics I will post later the axle bar hangers are totally distorted that's when I decided to chop
everything out.
Attached Thumbnails Transit cosworth rebuild project-img_3829.jpg   Transit cosworth rebuild project-img_3830.jpg   Transit cosworth rebuild project-img_3831.jpg   Transit cosworth rebuild project-img_3832.jpg   Transit cosworth rebuild project-img_3833.jpg
Transit cosworth rebuild project-img_3834.jpg   Transit cosworth rebuild project-img_3835.jpg   Transit cosworth rebuild project-img_3857.jpg   Transit cosworth rebuild project-img_3858.jpg   Transit cosworth rebuild project-img_3866.jpg
Transit cosworth rebuild project-img_3867.jpg   Transit cosworth rebuild project-img_3868.jpg   Transit cosworth rebuild project-img_3869.jpg   Transit cosworth rebuild project-img_3870.jpg   Transit cosworth rebuild project-img_3894.jpg
Transit cosworth rebuild project-img_3895.jpg   Transit cosworth rebuild project-img_3896.jpg   Transit cosworth rebuild project-img_3897.jpg   Transit cosworth rebuild project-img_3903.jpg   Transit cosworth rebuild project-img_3904.jpg
Transit cosworth rebuild project-img_3898.jpg   Transit cosworth rebuild project-img_3899.jpg   Transit cosworth rebuild project-img_3900.jpg   Transit cosworth rebuild project-img_3901.jpg   Transit cosworth rebuild project-img_3905.jpg
Transit cosworth rebuild project-img_3906.jpg   Transit cosworth rebuild project-img_3991.jpg   Transit cosworth rebuild project-img_4096.jpg   Transit cosworth rebuild project-img_4097.jpg   Transit cosworth rebuild project-img_4098.jpg
Transit cosworth rebuild project-img_4099.jpg   Transit cosworth rebuild project-img_4100.jpg   Transit cosworth rebuild project-img_4101.jpg   Transit cosworth rebuild project-img_4103.jpg   Transit cosworth rebuild project-img_4104.jpg
Transit cosworth rebuild project-img_4105.jpg   Transit cosworth rebuild project-img_4106.jpg   Transit cosworth rebuild project-img_4108.jpg   Transit cosworth rebuild project-img_4152.jpg   Transit cosworth rebuild project-img_4153.jpg
Transit cosworth rebuild project-img_4154.jpg   Transit cosworth rebuild project-img_4155.jpg   Transit cosworth rebuild project-img_4156.jpg   Transit cosworth rebuild project-img_4158.jpg   Transit cosworth rebuild project-img_4159.jpg
Transit cosworth rebuild project-img_4160.jpg   Transit cosworth rebuild project-img_4161.jpg   Transit cosworth rebuild project-img_4162.jpg   Transit cosworth rebuild project-img_4163.jpg
Old Jan 29, 2018 | 02:50 PM
frenchie rs
We are brothers.
Old Jan 29, 2018 | 05:27 PM
Caddyshack's Avatar
Caddyshack
We are brothers.
Careful, that's on jonfocs bucket list
Old Jan 29, 2018 | 06:39 PM
jonfoc's Avatar
jonfoc
You're well jealous!
Old Jan 29, 2018 | 06:42 PM
Frenchie72's Avatar
Frenchie72
Default Pan hard rod mounting point fabricated and strengthened
This bracket for the pan hard rod was originally welded to the O/S chassis trouble is they could not lay down a decent weld all the way round.
when I scraped all the sealant from the chassis there was a crack were it was welded also the bracket on the axle had been repaired in the past .
you will see in these pics I've strengthened it and I've been able to weld it all the way round .
the rear inner and outer valance have also been replace I was lucky enough to pick up an original ford panel the fit was perfect
Attached Thumbnails Transit cosworth rebuild project-img_4169.jpg   Transit cosworth rebuild project-img_4170.jpg   Transit cosworth rebuild project-img_4171.jpg   Transit cosworth rebuild project-img_4172.jpg   Transit cosworth rebuild project-img_4173.jpg
Transit cosworth rebuild project-img_4185.jpg   Transit cosworth rebuild project-img_4186.jpg   Transit cosworth rebuild project-img_4187.jpg   Transit cosworth rebuild project-img_4188.jpg   Transit cosworth rebuild project-img_4196.jpg
Transit cosworth rebuild project-img_4197.jpg   Transit cosworth rebuild project-img_4198.jpg   Transit cosworth rebuild project-img_4199.jpg   Transit cosworth rebuild project-img_4200.jpg   Transit cosworth rebuild project-img_4201.jpg
Transit cosworth rebuild project-img_4202.jpg   Transit cosworth rebuild project-img_4215.jpg   Transit cosworth rebuild project-img_4216.jpg   Transit cosworth rebuild project-img_4217.jpg   Transit cosworth rebuild project-img_4219.jpg
Transit cosworth rebuild project-img_4220.jpg   Transit cosworth rebuild project-img_4242.jpg   Transit cosworth rebuild project-img_4243.jpg   Transit cosworth rebuild project-img_4244.jpg   Transit cosworth rebuild project-img_4245.jpg
Transit cosworth rebuild project-img_4246.jpg   Transit cosworth rebuild project-img_4247.jpg   Transit cosworth rebuild project-img_4248.jpg   Transit cosworth rebuild project-img_4249.jpg   Transit cosworth rebuild project-img_4250.jpg
Transit cosworth rebuild project-img_4251.jpg   Transit cosworth rebuild project-img_4252.jpg   Transit cosworth rebuild project-img_4253.jpg
Old Jan 29, 2018 | 06:47 PM
jonfoc's Avatar
jonfoc
Borderline WRC spec transit I love it! Get rid of the shonky Gaz stuff, Leda is the way! But I'm bound to say that.
Old Jan 29, 2018 | 06:49 PM
jonfoc's Avatar
jonfoc
What lump is going back in?
Old Jan 30, 2018 | 07:15 PM
Frenchie72's Avatar
Frenchie72
Default Axle bar hangers cut out and replaced
You will see in the first few pictures how the hangers are distorted and are definitely not staying on any longer.
The O/S lower axle bar has sustained some damage I've no idea how see how the bar is bent out of shape.
However because of the Damage the hanger,and bracket on the axle were bent out of alignment by 10mm there was also a few cracks in the hanger
The N/S was in better condition but because the bolts used axle and hanger ends were threaded all the way.
They actually destroyed the rose joints and crush tubes in the bushes wore them out and the pick up holes were 2 mm bigger then needed.
The new hangers I've made have now got the ability to be adjusted both ends now and not just the axle end.
Just one question why would there be a nylon bushes in both lower axle bars and two black poly bushes in the top axle bars ?
im asking this because if there is a good reason for this I will replace the same.
Or I will replace with all poly bushes any ideas please.
Attached Thumbnails Transit cosworth rebuild project-img_0995.jpg   Transit cosworth rebuild project-img_1027.jpg   Transit cosworth rebuild project-img_1026.jpg   Transit cosworth rebuild project-img_1022.jpg   Transit cosworth rebuild project-img_4320.jpg
Transit cosworth rebuild project-img_4321.jpg   Transit cosworth rebuild project-img_4322.jpg   Transit cosworth rebuild project-img_4324.jpg   Transit cosworth rebuild project-img_4325.jpg   Transit cosworth rebuild project-img_4326.jpg
Old Jan 30, 2018 | 07:18 PM
Frenchie72's Avatar
Frenchie72
Default Axle bar hangers fabricated
This time round done better
Old Jan 30, 2018 | 07:42 PM
Frenchie72's Avatar
Frenchie72
Welded up and powder coated no rust
Attached Thumbnails Transit cosworth rebuild project-img_4366.jpg   Transit cosworth rebuild project-img_4367.jpg   Transit cosworth rebuild project-img_4410.jpg   Transit cosworth rebuild project-img_4411.jpg   Transit cosworth rebuild project-img_4412.jpg
Transit cosworth rebuild project-img_4413.jpg   Transit cosworth rebuild project-img_4414.jpg   Transit cosworth rebuild project-img_4415.jpg   Transit cosworth rebuild project-img_4495.jpg   Transit cosworth rebuild project-img_4496.jpg
Transit cosworth rebuild project-img_4513.jpg   Transit cosworth rebuild project-img_4514.jpg   Transit cosworth rebuild project-img_4515.jpg   Transit cosworth rebuild project-img_4542.jpg   Transit cosworth rebuild project-img_4543.jpg
Transit cosworth rebuild project-img_4544.jpg   Transit cosworth rebuild project-img_4545.jpg   Transit cosworth rebuild project-img_4546.jpg   Transit cosworth rebuild project-img_4548.jpg   Transit cosworth rebuild project-img_4549.jpg
Transit cosworth rebuild project-img_4550.jpg   Transit cosworth rebuild project-img_4551.jpg   Transit cosworth rebuild project-img_4552.jpg   Transit cosworth rebuild project-img_4553.jpg   Transit cosworth rebuild project-img_4557.jpg
Transit cosworth rebuild project-img_4558.jpg   Transit cosworth rebuild project-img_4559.jpg   Transit cosworth rebuild project-img_4560.jpg   Transit cosworth rebuild project-img_4564.jpg   Transit cosworth rebuild project-img_4565.jpg
Transit cosworth rebuild project-img_4566.jpg   Transit cosworth rebuild project-img_4567.jpg   Transit cosworth rebuild project-img_4568.jpg   Transit cosworth rebuild project-img_4569.jpg   Transit cosworth rebuild project-img_4575.jpg
Transit cosworth rebuild project-img_4576.jpg   Transit cosworth rebuild project-img_4445.jpg   Transit cosworth rebuild project-img_4446.jpg   Transit cosworth rebuild project-img_4447.jpg   Transit cosworth rebuild project-img_4448.jpg
Transit cosworth rebuild project-img_4449.jpg   Transit cosworth rebuild project-img_4493.jpg   Transit cosworth rebuild project-img_4503.jpg   Transit cosworth rebuild project-img_4512.jpg   Transit cosworth rebuild project-img_4517.jpg
Old Jan 30, 2018 | 07:47 PM
jonfoc's Avatar
jonfoc
Bugger me you don't hang about. It's looking bomb proof already. Do you have all the tools in your workshop for this stuff or are you getting stuff sorted elsewhere and welding it up in your garage?
Old Jan 30, 2018 | 08:01 PM
Frenchie72's Avatar
Frenchie72
All being done in my shed I have a lot of tools if I don't have then I will make it if I can the only work that's been carried out by a professional is my brake bells and caliper brackets by Mark at Mk Motorsport
Old Jan 30, 2018 | 08:02 PM
jonfoc's Avatar
jonfoc
Skills!
Old Jul 3, 2018 | 09:17 PM
K888MJA's Avatar
K888MJA
Good to see the van getting some much needed tic ��
Old Jul 29, 2018 | 09:57 AM
K888MJA's Avatar
K888MJA
Any new updates ?
Old Jul 29, 2018 | 11:58 AM
Caddyshack's Avatar
Caddyshack
Love the work that has gone in to this van
Old Jul 29, 2018 | 12:28 PM
visa_broke's Avatar
visa_broke
10 Year Member
First time seeing this thread, I am sure I saw pictures of this in magazines before when it was blue and yes definately needs to be blue!
