What’s this and how’s it work
Old Jan 26, 2018 | 05:46 PM
timsrs's Avatar
timsrs
Default What’s this and how’s it work
Can someone tell me what this does and is it needed
Sounds like something is loose internally in the black cylinder
Thanks
Old Jan 27, 2018 | 07:19 AM
Ridgey's Avatar
Ridgey
Fuel vapour trap I believe.
Don't know how it actually works and when ....?
Old Jan 27, 2018 | 08:18 AM
Caddyshack's Avatar
Caddyshack
I assume they are a carbon filter and if so they would be service replacement. It goes on one of the breathers from the tank.
Old Jan 27, 2018 | 09:02 AM
timsrs's Avatar
timsrs
I think the filter must be in the black cylinder
Not sure what the white valve is for
Old Jan 27, 2018 | 10:09 AM
focusv8's Avatar
focusv8
If there is something loose it will be a ball valve (or a loose filter!)
So it probably collects vapour, when enough vapour turns to liquid and fills the black cylinder the ball valve will lift and return fuel to the tank.
Old Jan 27, 2018 | 10:24 AM
timsrs's Avatar
timsrs
Originally Posted by focusv8
if there is something loose it will be a ball valve (or a loose filter!)
so it probably collects vapour, when enough vapour turns to liquid and fills the black cylinder the ball valve will lift and return fuel to the tank.
Old Oct 7, 2018 | 02:09 PM
The Youth.'s Avatar
The Youth.
its a roll over valve, the loose thing is the ball so that when you roll it blocks the pipe to stop fuel coming out
Steve
Trist
13
May 5, 2009 07:39 PM
fatty
Aug 6, 2007 01:05 PM
SS1
13
Jan 15, 2007 07:57 AM
s2_rsturbo
Mar 12, 2006 07:25 PM
Ginge !
22
Apr 28, 2005 10:44 PM
