Compression query
Old Jan 25, 2018 | 08:15 AM
MarkHulme's Avatar
MarkHulme
Default Compression query
Reply to Thread
Tags: None
  1. Mark 1 said:25-01-18 08:51
    Compression query
    Further to an issue I had with my 2004 Ford Focus 1.8 a while ago , I was advised to carry out a compression test , which I duly did.
    Compression ranged from 70 lb/ sq. in. to 100 lb/in. sq.
    Given that my car suddenly lost power without any warning whatsoever , and the fact that I've already replaced plugs , leads and coil , what are the chances that the valve timing has 'slipped' due to the cambelt ?
    I fitted a new belt and tensioner about 7 or 8 years ago , but haven't yet done enough miles to replace it again .
    I understand that cambelts rarely jump in sprockets but it can occasionally happen .
    If the belt has indeed slipped , it would fully explain the instant power loss.
    Many thanks.
russ rs
May 22, 2011 01:19 PM
dake205
Jan 19, 2010 06:33 PM
Clare
Escort RS1600i
28
Dec 16, 2009 07:42 PM
PJay
Technical essay Archives
202
Oct 12, 2008 02:10 AM
series_one_rst
14
Aug 28, 2007 05:06 PM
