Capri - advise on rolled arches for bigger wheels and lowering...
Old Jan 14, 2018 | 05:35 PM
TomPengelly's Avatar
TomPengelly
Kapow!!
Default Capri - advise on rolled arches for bigger wheels and lowering...
So I have a mk3 Capri, it’s currently a painted rolling shell.
I want to fit these wheels (that I already have) they are 8.15 and an offset of -8
What’s involved with “rolling and flairing” the arches? I know I sound like a 17yr old with a Corsa Sxi when I say this- but can I use the arch rolling tool that bolts to the wheel hub that’s 30 quid on eBay?
To get it low, I was going to buy coilovers all round. What’s involved in removing the leaf springs and fitting coilovers to the rear?
Thanks in advance. I was hoping to make it sit something like this..
Cheers!
Old Jan 14, 2018 | 06:47 PM
Caddyshack's Avatar
Caddyshack
I have been through this. Pay someone to cut the arches back as far as they can, weld them and seal with seam sealer, it's the only reliable way to do it. The phirm in Farnham Surrey are not too far away from you, they can do this all day long and have the bodywork connections.
Sweet wheels and very cool car by the way.
Old Jan 14, 2018 | 06:48 PM
Caddyshack's Avatar
Caddyshack
If you do try rolling make sure the paint is is hot as you can make it, people have done it with baseball bat, hot paint and lever against the tyre.
Old Jan 16, 2018 | 03:01 AM
Wessa's Avatar
Wessa
From: An Essex lad now in Christchurch, New Zealand.
If you really want to rework it, I would, if it was me hunt down an x pack and really smash it..
Old Jan 16, 2018 | 05:53 AM
Shaun's's Avatar
Shaun's
I don’t think that car is his....
Old Jan 16, 2018 | 06:30 AM
cossynut2's Avatar
cossynut2
10 Year Member
The Silver Capri is just an example of what he is looking at , not his own car. I would say that it is to low and the rear tyres probably rub on the arch when the extra weight of passengers are in it plus going over speed humps etc. As Caddyshack has said if you want to have really big wheels and tyres on a very low car to get it right extensive arch modification is the only way to go.
Old Jan 20, 2018 | 11:14 PM
puddy's Avatar
puddy
Cheers!
To fit coilovers on the rear you will have to 5 or 6 link the axle , you would be better off getting your leaf springs de cambered and fitting lowering blocks .
To fit the link kit you will have to fit link boxes to the shell which involves a lot of cutting and welding.
puddy
Old Jan 21, 2018 | 10:30 AM
lee2cossies's Avatar
lee2cossies
puddy
Iv just 5 linked my Capri it’s a lot of work as nothing Escort is a direct fit, lots of cutting shortening and welding needed! You can still fit coilovers to leaf springs I believe, but the turret boxes need seam welding.
Old Jan 21, 2018 | 11:17 AM
puddy's Avatar
puddy
I know that , but you would have to use slipper springs for coilovers / linked rear end. And they were only used to get round the rallying regs I believe.
puddy
PSL
Sep 6, 2006 06:53 PM
PSL
Sep 4, 2006 08:39 PM
Charlie Chalk
Apr 29, 2005 02:35 PM
G500COS
18
Jan 13, 2005 01:20 PM
