Ford Focus (All Models) This forum is for discussion of all things pertaining to the Ford Focus Range that doesnt belong in the seperate ST & RS sections..
Ignition Problem !
Old Jan 8, 2018 | 12:42 PM
MarkHulme's Avatar
MarkHulme
Question Ignition Problem !
Hi guys. I'm new to this site so I hope I don't break any forum 'taboos' !
I have a problem with my 2004 Focus 1.8 petrol.
My car suddenly started to lose power and when I stopped , it ran really 'lumpy'
The breakdown guy towed me home and then performed a diagnostic test which gave the error code P0351 and said it indicated a faulty coil.
It turns out that I have no spark on cylinder number one so I checked the resistances in the coil and the HT leads which all seemed to be satisfactory (according to my Haynes manual) leading me to suspect a faulty plug.
When I removed the plugs , number one had an excessively large gap so I thought I'd found the problem but the problem was still there !
Still being reluctant to blame the coil , I did some online research and discovered that the coil in my wife's 2004 Fiesta shared the same specifications as the coil in my Focus , so I temporarily swapped them over together with the HT leads.
This made no difference at all ! My wife's Fiesta ran perfectly well with my coil and HT leads and my car still failed to run properly using her Fiesta's components so I'm now assuming that if my coil and HT leads work perfectly well in my wife's car , they must be perfectly good !
I understand that these coils work on the 'wasted spark' principle and that one coil operates plugs 1 and 4 and the other coil operates plugs 2 and 4. Surely this means that if plug 4 is firing , then the fault can't possibly be the coil , the wiring between the coil and ECU , or the coil 'switching' mechanism in the ECU itself (coil drivers) , otherwise NO plugs would fire OR only 2 and 3 would fire !
I'm totally baffled by this !
Any advice would be so very gratefully appreciated !
Many thanks ! 🙂
Ade
Mar 17, 2012 08:43 PM
scoooby slayer
11
Oct 28, 2007 10:15 AM
MK5RST
Dec 9, 2004 09:09 PM
MK5RST
Dec 5, 2004 09:33 AM
