Ford Focus Range This Section Contains All The Ford Focus Model Specific Forums.
Heated windscreen DTC Code
Old Dec 19, 2017 | 05:39 PM
Pitbull69's Avatar
Pitbull69
Default Heated windscreen DTC Code
got a ST170 and was using Forscan and its had errors in there from ages ago, all got deleted at a garage but forscan has obviously kept them, most have been removed but im stumped on 2 that wont delete
Code B2256 - Heated Windscreen relay short to ground Heated window seems to be working perfectly but is this a warning its about to go wrong ?
Also have a Code B1550 - Global closing window motor circuit short to ground, I dont have global closing as only got a 3 door (Wish I did have it though) I did break the window regulator at the weekend by forcing the window down when it was frozen over, could this cause that ? haven't changed it yet as havent found a replacement locally.
Old Dec 21, 2017 | 10:54 AM
t230's Avatar
t230
theres two earths in the passanger footwell behind plastic trim...check those, held by 10mm bolts....
That Forscan is good..have you used it to mod your GEM module yet? you can turn on/off things like 'rear wiper auto when reversing'
Old Dec 21, 2017 | 03:33 PM
Pitbull69's Avatar
Pitbull69
cheers bud, I shall give them a go
I haven't yet, wanted to get all codes clear before having a play,
bassboy
Jun 2, 2011 11:00 AM
robertadkinsjr
Ford Focus RS
Sep 5, 2010 05:51 PM
Franko99
11
Jul 18, 2010 10:21 PM
robholmes
Ford Focus ST
Mar 18, 2010 02:19 PM
ryan_belfast
Jun 18, 2009 02:38 PM
