Crankshaft seal
Old Nov 27, 2017 | 05:46 PM
apewrench's Avatar
apewrench
Default Crankshaft seal
Hi,
i was swapping the timing belt & waterpump (Focus 1.6 "Sigma" petrol, 2009), when i noticed the outer crankshaft seal is leaking a tiny bit. Also the belt was a bit jagged/eaten on the inner side - softened by oil? a grease residue under the crank?
I went about changing the seal, without special tools, metal tubes etc. Tried gently tapping it in with a small hammer & a 1/2" extension bar.
Well, it went in, but not as evenly as i'd like - one side sooner, then i leveled it out. Now it's deeper than flush, about a milimeter. Is that a problem on a Focus crank, the stop "thing" (1st picture) ?
I read it would seal better, since it's seated behind the groove left by the old seal.
Well, the real problem, (or not? i don't know, i'm a first timer with this) : the gap between the shaft and the inner side of the seal varies around the circumference. On the left side there's an air gap (about 0.5 mm or slightly less- just as it was on the original seal, which had 100k miles ~ 160k km on it), but on the right there's even a smaller gap with fresh oil (which i put on the inner side to lubricate it), held by surface tension. One short length of the seal seams like it's almost touching the crank.Is this doomed to fail soon or am i overthinking this? Within tolerance or way of center? Should i reinstall a new seal with the help of metal tube? Freezing weather is catching up on me, so i better hurry, got 1 day left :/
Could the seal hit the "thing" behind it, on the left of the crank, bending the inner lip? Spring fell off? i was gentle as possible. . . the outer edge of the seal seems about even, but i can't rectify the inner gap to make it even, no matter where i tap now.
Your help MUCH appreciated!
Attached Thumbnails Crankshaft seal-pb270518-large-.jpg   Crankshaft seal-pb270524-large-.jpg   Crankshaft seal-pb270527-large-.jpg   Crankshaft seal-pb270529-large-.jpg   Crankshaft seal-pb270536-large-.jpg
coswol
12
Aug 24, 2008 01:49 PM
Azrael
May 20, 2007 06:49 AM
dave_y
May 28, 2006 01:00 PM
SPADGE
11
Apr 5, 2006 03:50 PM
Chipperx2
Sep 25, 2004 05:32 PM
