Rear crankshaft oil seal replacement
I am currently rebuilding my bottom end and am trying to fit a new rear seal
If i put it in before tightening the rear mains cap it gets pushed out on tightening!
How do you fit it once the crank is in?
Cheers Spadge...
Cheers Spadge...
Originally Posted by JTECHSAFF
the seal comes with a plastic sheild which helps to fit it. ![Surprised](https://passionford.com/forum/images/smilies/bigcry.gif)
I have no plastic shield so what exactly are you meant to do with it and why the
Football Cwazy
i fitted mine after the mains were fitted,just slides over the crank and then i tapped it gently but firmly ( if you get what i mean
) whilst continuously moving around the circumference of it ( so you don't push one side in too much at a time)
Passion for Fords!
The plastic sheild is there to stop the inside of the sheild catching the crank, you place it over the crank end and slide the seal in, then remove the plastic jobby, and tap it home with either the old seal, or somin soft.
The
was because people always throw the plastic jobbie away
The
st220kyle
16
14-08-2015 06:13 AM
