RS Turbo running problems
Old Apr 11, 2005 | 07:03 PM
Gra's Avatar
Gra
Default RS Turbo running problems
Finally got my RS Turbo running again but its not running right, basically it was ok, then i changed the Head Gasket, put on Cossie Turbo, new alternator, although due to other commitments the car was left in bits for about 6 weeks or so, put it all back together last night, and it just starts but is really lumpy and sounds like its gonna cut out just checked the timing and it seems ok, plugs seem to have carbon deposits on tips so will need changing but what coud cause it to run really lumpy? and how can i fix this
Old Apr 11, 2005 | 09:02 PM
Max's Avatar
Max
So you fitted the cambelt at TDC, have you tried adjusting the position of the Distributor? move it slightly left or right
Possibly the fueling is out so it's over or under fueling
Check that the flap in the metering unit is moving freely and that there are no air leaks
M
Old Apr 11, 2005 | 10:57 PM
no grip's Avatar
no grip
have you blanked off all unnecessary air intakes to boost pipes - breather systems etc?
Old Apr 12, 2005 | 05:27 PM
Moonie's Avatar
Moonie
Does sound like an air leak as said above, check all pipes/hoses.
Old Apr 12, 2005 | 07:03 PM
Rs1's Avatar
Rs1
If all the pipes are fitted and are not holed/split and the timing is good it may just need ran up a little. Try raising the revs for a peroids of time to clear out any cobwebs. if this doesnt work take it to your local rollin road for a fuel and ignition setup.
Old Apr 12, 2005 | 07:04 PM
Rs1's Avatar
Rs1
Silly question,do you have the plug leads on in the correct firing order??
Old Apr 12, 2005 | 08:12 PM
Gra's Avatar
Gra
just fired it up and it sounded a bit better but still lumpy, got the day off tomorrror so gonna check all the hoses, will check evrything tomorow am, cheers for the helps peeps
Old Apr 12, 2005 | 08:29 PM
Max's Avatar
Max
if ya want a hand tomorrow mate i am around most of the day
big_Rad
Sep 15, 2017 09:36 AM
3i Jim
Nov 20, 2015 05:12 AM
Churtz
15
Aug 13, 2015 06:40 PM
Zoggon
Aug 10, 2015 10:39 AM
turbobill
Aug 9, 2015 05:21 PM
