whats it worth? freshly rebuilt 200 blocked yb
Contemplating breaking my 2wd cossie, starting with the engine which ive just had rebuilt by a reputable builder. Below is the spec list but ive no idea what an engine is worth these days. Happy to take it to pm if this upsets the mods, at the moment i am planning on keeping her, depending on how my finances go. But ive just got out of hospital surviving pneumonia and blood poisoning so no time to build and no money at the moment!
So you have a brand new 200 block with new standard size Mahle Pistons . Standard size crank polished & balanced along with the crankshaft pulley wheel , skimmed flywheel & brand new Ap racing organic clutch .
ARP stud & nut kit fitted to the main caps .
Arp Conrod bolts .
New standard size bearings & thrust washers .
New oil pump .
2wd Sapphire cylinder head lightly skimmed . Looks like it's been ported . All valves have been removed cleaned , decoked and lapped in .
New oil seals , all guides checked . Newman cams BD14 inlet , BD10 exhaust
Arp head stud & nut kit
Cometic mls head gasket .
All new genuine seals & gaskets .
4x4 inlet with 10mm spacer
Good for 400bhp at 2 bar of boost
Arp Conrod bolts .
New oil pump .
Ł8k, surely you are having a laugh.
Sounds like a good engine, but I fail to see what 'special' ingredients are in it to justify what you suggested, based on the items listed above.
I certainly agree that you could easily spend over Ł8k assembling all of those parts.
Also, when I said Ł5k plus that means just that, could be more, much more.
Ebay it thiers a good spec one on thier now fresh tebuilt roper head cams for 500+ thats at 5500 1 day to go id say about 4-5 you see people put them on here stupidly high and they just sit thier then get reduced the 6k 205 engines i see make me laugh as said you have got the fact its a brand new block going for you or caddyshack he'll give ya 20k for it
i also laugh when I see exspensive 205 blocked engines
Be a tough choice for me with the old engine from yum knocking about on Facebook. 200 block liners arrow crank proper rods pistons inlet manifold the works for 13 grand
Pretty sure it was Mark Shead.
Edit: found this thread, was originally a 2.2 stroker build by MA Developments.
https://passionford.com/forum/restor...deo-added.html
Had a good read through...that's pretty much the spec I would want to run my 205 at but with the smaller BW to fit in the engine bay and I don't think I need more than 580 bhp in my little 205 as 469bhp is pretty mental.
Arp Conrod bolts .
New oil pump .
Arp Conrod bolts .
New oil pump .
Cheers Paul
Last yb I sold was about 7 years ago roughly, 200 block, 7.5 c/r, ap clutch, bd14 cams, big wing sump, made 472 hp had done 4k miles sold for Ł2500 iirc
The true value is what someone is willing to pay.
This can be very different to what people put things up for sale.
Therefore the best advice would be from someone who has actually either just Bought or Sold a similar spec engine.
Common sense to me would be the value of the same spec 205 blocked engine plus about Ł1k (to allow for the 200 block).
12 to 1600 block
750 crank
rods 120
flywheel 50
clutch 200
at studs worth nothing really
head 1000
I'd say built up if say 5k with pistons
remember this what things are advertised for are not the realistic selling price
750 crank
rods 120
flywheel 50
clutch 200
head 1000
I'd say your pricing for parts is bang on jay going off of what I see on eBay on a bid, realistically I reckon all in 6k.
