aluminum radiator mk5 escort
Old Oct 10, 2017 | 10:30 PM
tockwell's Avatar
tockwell
Default aluminum radiator mk5 escort
Does anybody know where I can get an aluminum radiator for a mk5 escort?
Old Oct 11, 2017 | 08:30 AM
massivewangers's Avatar
massivewangers
Not sure if there is anything available off the shelf. Cheap solution if you want something slightly bigger is to use the rad of an Escort with air con, as I think these are a bit wider.
I'm sure someone would make you something. Mat at MDA Motorsport might be able to do you an F2/Maxi style one perhaps.
Old Oct 12, 2017 | 06:20 AM
jonfoc's Avatar
jonfoc
If you've still got the old one. Ship it to Jim at alloy racing fabrication he can make a new one for you.
McGoo 69
Apr 29, 2015 05:28 AM
rsturbo91
Jun 3, 2012 04:20 PM
Richardpaulh
May 18, 2011 01:28 PM
ford-escort-rs-turbo
Jan 20, 2010 09:39 AM
