Tyreweld?
It does work, YES. I found the best product to be SLIME, it comes with an air pump to put it in. When I built my e-chopper I used it to seal the rear rim as I could not get the spokes to hold air no matter what I did, one bottle of that and the tyre has not needed any air in 6 months.
What Toby says. Tyre weld to get you safe in an emergency. Used it a couple of times and it wrecked the tyre so it had to be replaced. But at least I wasn't flattened on the hard shoulder.
Proper tyre weld poses no problem to tyre repairs. Its solluble and just hoses of and is no impediment to an effective repair. The National Tyre Distribution Association endorse it.
Slime is OK, but doesn't inflate the tyre like a tyre weld product does. Put it in a healthy tyre and it holds off punctures, but won't seal them for ever so you're tyre will still go down, just at another time.
If your tyre is in good condition why not get it repaired properly? Have you not got a spare wheel and tyre? It is not very expensive for a repair and you will know its been done to the right standard. When it comes to tyres I would want to know its safe to use.
A small hole, large hole, gash, chunk out of sidewall etc etc etc.
Not all punctures are the same, and you dont mention type o tyre, vehicle, etc.
So it can work in some cases...it others it may not.
A spare wheel tends to work well though
And Even more idiots on the road seem incapable of changing one.
And even more again seem incapable of recognising they have a puncture and drive on until the tyre is destroyed and not a flucking chance tyre weld will do anything lol
My cmax has a spare wheel well, but the 3rd row of seats are on top of it so you couldn't get a spare into it if you tried
Fiesta also came with a tin of foam and a compressor, binned that and bought a spare wheel kit for it.
Far too many modern cars dont have one !
The price of a new car should include a full sized spare wheel and tyre !
popped into ford garage today and saw a new fiesta for sale, on the windscreen was list of all the features sat nav, park sensors, aircon, etc and there on the list was a spare wheel! HOW TIMES HAVE CHANGED, A SPARE WHEEL A SELLING FEATURE.
I bet it wasn't even a spare alloy either, probably a shitty little thing about 5" wide
The money it costs for a new car these days should include as standard a proper full sized spare wheel.I have never bought a new car but if I was I would insist on it having one. The dealer is not going to turn down a sale for what it would cost them. What has changed that makes dealers think a spare wheel is no longer required?
I have even got 5 alloy wheels and tyres all the same make and size for my Saff!
When built
to be fair in the 90s the wheels and tyres were getting so wide they were taking up to much room compromising luggage space so i can see why they went down the space saver root but as for this expanding foam well what good is it if your tyre is blown or the bead is broke and now you are stranded, surely a safety issue or is this just another [only when it suits ] drawn up by the eu dickheads.
One of my mates worked on the production line for Transits at Ford. They couldn't work out why the stock take firgures for spare wheels was always out.....until they caught a bloke who was rolling a wheel a week off a roof and bouncing it over a fence, he was selling them in his local.
New Range Rover has full size spare as an option.
i remember in the 70s regularly seeing the rover 3500 p6 with the wheel in a cover mounted on the top of boot, cant of seen anything out the mirror, i dont recall any other cars from this era doing this.
You have too many toys
I've just been out and bought a new daily driver this week, me and the wife was showing her dad it and we found out it actually has a spare. They looked proper shocked, both there 2016 cars don't. My 2003 audi thats just been put up for sale should have if the previous owner hadn't robbed it before I got it. I nearly needed it one night but managed to limp the car home, sounded like i'd put a cv joint out and found a huge bolt in the rear tyre.
One of the reasons I've been looking into hidden air ride tanks for a project so I get to keep the boot space and the spare.
i just had to use this tyreweld yesterday as the tyre place would not repair the tyre as it was over 6cm and they said it on its last legs but there was plenty of tread left and it was a Good Year tyre so I whacked some tyreweld and its been fine since.
Would only recommend it on tyres that are at the end of their life really as it destroys the inside of the tyre.
