Gearbox or Diff temp.
Old Sep 29, 2017 | 10:27 PM
Ridgey's Avatar
Ridgey
Default Gearbox or Diff temp.
What would you consider most useful (or which is most likely to overheat), measuring gearbox temp or rear diff temp ?
Old Sep 29, 2017 | 10:42 PM
McCloud 85's Avatar
McCloud 85
I do not confess to knowing much or anything about this particular topic, but my instinct would be to measure the gearbox temp. I would imagine that will run potentially hotter due to more moving parts and heat transfer from the block. They also tend to be the more expensive part to replace/repair out of the two. So I would rather know if that was going wrong if I had to pick between the two. In an ideal world you would want to measure both. Especially for a track car I would assume. Do they need close monitoring?
Old Sep 30, 2017 | 09:22 AM
Ridgey's Avatar
Ridgey
I've never measured them before, but upgrades I'm making give me the opportunity to easily measure a least one of them.
So it would be rude not to.
Old Sep 30, 2017 | 11:10 AM
Caddyshack's Avatar
Caddyshack
I wonder if you could wire in both and just have a switch to swap between each sender?
The diff could easily have a boot mounted gauge as you don't need to be checking it all the time
Old Sep 30, 2017 | 12:19 PM
Adam-M's Avatar
Adam-M
I'd be tempted to fit a diff cooler and then monitor the gearbox and possibly add one there too
Old Sep 30, 2017 | 03:18 PM
Ridgey's Avatar
Ridgey
Thinking about it I may just have a long lead on the sensor so I can screw it into the gearbox or the diff. And monitor both just on different occasions
Sensor will be connected to ecu and displayed via an ecu display system.
Old Sep 30, 2017 | 03:23 PM
Ridgey's Avatar
Ridgey
Probably don't need a diff cooler, measurement of temps is the first step then you can make an informed decision whether to fit one or not..
YOREVOL
Mar 8, 2013 09:10 AM
MT-Motorsport
Apr 4, 2012 05:35 PM
FletchCossie
Ford Escort RS Cosworth
Sep 18, 2009 10:21 PM
pd
Feb 22, 2008 07:14 PM
R5COS
Oct 31, 2007 08:43 AM
