The heater motor should run even when its not switched on. Remove the panel under the wiper motor and check to see if there is any power going to the plug.
check the connectors on top of the blower motor itself, one of mine was corroded and didn't work unless you gave it a wiggle. well worth a look before you pull it apart too far.
not on his car mate,it's going to be at least a 90 spec so you can turn them off
there is a microswitch that kills the power to it when both the sliders are set to the bottom position, check this one to make sure it's not stuck, it's behind the dash binnacle though so you need to get the screwdrivers out
once you've got the cover off you will see 3 screws holding the controllers in place, unscrew all these and you should be able to pull the unit out and access the switch
the other problems these had was the blower dial itself packing up
and then there's the wiggle test on the wires for the blower motor
So it seems the actual motor has packed up, I'm guessing there are no longer available. Apart from buying a used one does anyone know if a repair service?
My shonkys 93 and you are correct kills the blower
It has aircon yes, there's no bolts on either side that's what i thought also so i'm a bit lost here
It looks like you can get the top off but it's stuck for some reason and there's no bolts or screws, btw it's a Italian imported car
from the picture it looks like there is another cover over the top
can you remove that?
i don't have a sierra handy otherwise i'd take a pic of the normal set up where you can quite easily spot the two nuts either side of the fan motor that anchor it into place
but you then mention that it's italian, and they have a 100% record in building cars with excellent wiring don't they
I can’t get the top removed as there’s no bolts or screws in sight
There must be a method to remove it but it’s indeed a Italian import so who knows
