Saph rear to low
Just wondering what you guys with saphs are running rear spring wise
mines dragging its arse a bit more than I'd like, just want to level out the stance
thanks
thanks
That sounds a spring length problem if it is too low more than poundage.
It might be worth getting a standard spring and seeing where it sits from there. Has the old spring broken, is it non standard?
Are the springs old and starting to sag.?
Probably best to buy a new full Spring set as they are usually quite inexpensive. Just need to find out which make you like the ride height of front and rear.
Some lowering spring kits I've fitted give sierras the bum down appearance, I got that peed off with a few sets I tried on my 3 door I put coilovers on that way I can set them to look spot on
As others have said another option is to fit coil overs which can be adjusted to get the ride height spot on.
