Saph rear to low
Saph rear to low
Just wondering what you guys with saphs are running rear spring wise
mines dragging its arse a bit more than I'd like, just want to level out the stance
thanks
thanks
That sounds a spring length problem if it is too low more than poundage.
It might be worth getting a standard spring and seeing where it sits from there. Has the old spring broken, is it non standard?
Some lowering spring kits I've fitted give sierras the bum down appearance, I got that peed off with a few sets I tried on my 3 door I put coilovers on that way I can set them to look spot on
As others have said another option is to fit coil overs which can be adjusted to get the ride height spot on.
