Pinto valve clearance impossible
Old Aug 26, 2017 | 05:59 PM
Mark Cuddy's Avatar
Mark Cuddy
Default Pinto valve clearance impossible
Hi,
I'm not really mechanically minded but I can follow a Haynes manual.
I'm putting together the pinto from my cortina and am rebuilding the head...new camshaft, new rockers but I can't achieve any valve clearance whatsoever with the adjusting bolts at any position. Has anyone encountered this and if so what's the course of action....taking the rockers to be machined?
Thanks
Old Aug 26, 2017 | 06:01 PM
Caddyshack's Avatar
Caddyshack
It sounds like something is not right or being done right if you have standard parts and cannot match up to Haynes?
Old Aug 27, 2017 | 08:44 AM
COLEYST200's Avatar
COLEYST200
Looks very simple to me
Old Aug 28, 2017 | 03:45 PM
Mark Cuddy's Avatar
Mark Cuddy
Default It should be simple
I agree, should be simple but all of my adjusters are set for maximum clearance and I have nothing....could it be that I've been sent a non-standard camshaft?
Old Aug 28, 2017 | 05:50 PM
Mark V8's Avatar
Mark V8
Did you keep your old cam ?
If you still have it you could compare base circle diameters.
Have the valves been lapped in excessively or re-cut as that would move them back in the head ?
Old Aug 29, 2017 | 11:15 PM
Turbo Zetec's Avatar
Turbo Zetec
Engine Machinist
pictures of what you're doing would be best as we can only guess at what's wrong currently. i doubt you'll be out of adjustment as pintos have a ton.
Old Sep 10, 2017 | 06:41 PM
essy's Avatar
essy
Have you changed the valves? some valves are slightly longer than standard.
