Hello need someone to do me a favour please. can someone measure the distance between the two front suspension turrets on there sierra please. as I have bought an omp strut brace and it is wider than the turrets on my sierra floorpan! just need a measurement from edge to edge please
Is that centre to centre or edge to edge ? And just to confirm what cosworth do you have ? Saph etc ? That measures the same as mine tho and strut brace measures 890mm bolt to bolt "where it bolts to the bracket" what strut brace are you running, any pictures ? Thanks for your help mate
Just an idea unless you have done so already. Raise the front of the car in the middle on the engine/rack cradle and see if the turrets open up a little then that would aid in getting the strut brace on??????? Might be wrong.
you could always cut the brace and weld a nut on each piece then add a piece of threaded bar in the middle??itll need repainted but it can be made to fit
Well yea that will be my option. But when you buy one for a sierra cosworth it should fit a sierra cosworth! Lol. I want the brace you have that is a graham Goode one I belive ? Can't find one anywhere
If I can't find one then I will be buying it. I got my friend to measure his saph. And he has a measurement of 860mm also. This brace must be made wrong?
I think that imp have bagged a bunch of them wrong. Thanks for your help mate. If you see a brace like yours come up forsale let me know please would appreciate it! Maybe I will find one at classic ford if not.
