What throttle body upgrades are there for cossies using level 8 500bhp+?
Old May 18, 2017 | 02:47 PM
forevaford's Avatar
forevaford
Default What throttle body upgrades are there for cossies using level 8 500bhp+?
As title really, I'm trying to remain my Std management, but always thought the throttle body looks small in these. It's a saph cossie gt3076 spec, also thinking about using the auto specialist inlet manifold. Just need bigger throttle body options please
Old May 18, 2017 | 03:32 PM
Caddyshack's Avatar
Caddyshack
My car is near on 500bhp and the throttle body is standard. I have got the Hart manifold.
MK Motorsport and a few others do larger throttle bodies if needed. I have got a larger throttle body on the shelf but have not used it so far.
Old May 18, 2017 | 03:46 PM
forevaford's Avatar
forevaford
It's just being able to use the Std tps ain't it. Not too fussed on the iscv but it would be nice to remain that as well
Old May 18, 2017 | 03:56 PM
Caddyshack's Avatar
Caddyshack
Not sure where my bigger one came from originally but it too runs the standard TPS and has ISCV too.
With a bit of work you could get the TPS mounted on anything with a spindle on it.
Old May 19, 2017 | 11:25 AM
Ridgey's Avatar
Ridgey
Aren't the RS500 throttles larger ?
Old May 19, 2017 | 11:28 AM
costina's Avatar
costina
Live long and prosper!!
There is a guy on ebay who can mod the std body for a larger butterfly.
Cost about 100 quid.
Old May 19, 2017 | 11:31 AM
costina's Avatar
costina
FORD SIERRA COSWORTH - GASFLOWED ANTI LAG THROTTLE BODY eBay
http://m.ebay.co.uk/itm/FORD-SIERRA-COSWORTH-GASFLOWED-ANTI-LAG-THROTTLE-BODY-/380297902926?nav=SEARCH
Old May 19, 2017 | 12:49 PM
Caddyshack's Avatar
Caddyshack
That would do the job then!
Old May 19, 2017 | 02:36 PM
costina's Avatar
costina
Thanks.
The link never seems to come out right for me.
Wonder what the std body will flow in terms of power.?
Old May 21, 2017 | 07:02 PM
lee2cossies's Avatar
lee2cossies
Thanks.
Harvey told me that he's seen 700hp a few times on his engine dyno with a standard throttle body and there's no need to change unless going beyond that.
Old May 21, 2017 | 07:06 PM
costina's Avatar
costina
Harvey has prob forgotten more stuff than most tuners/engine builders know.
I am sure the op will appreciate that info.......
Old May 22, 2017 | 12:23 AM
1374lee's Avatar
1374lee
yes I was also told a standard t/b will flow way over 500bhp. Some tuners advise change at around 550, I won't name them though.
Thanks. Lee.
Old May 22, 2017 | 10:27 AM
Caddyshack's Avatar
Caddyshack
Thanks. Lee.
In theory they could flow up to 700bhp but actually be causing some restriction / heat etc..at 550bhp and therefore by removing the restriction with a larger body you improve the efficiency...therefore it doesn't hold the power back at 550 with no further gains until removed but could benefit in some way potentially.
Old May 22, 2017 | 12:20 PM
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
When I had 500 I used a small turbo escort one sure mark said it gives better response there larger than the 2wd one
Old May 22, 2017 | 08:24 PM
1374lee's Avatar
1374lee
Yep, Mark advised using the st escos t/b when I had my 3dr which was around the 500bhp figure.
Thanks. Lee.
Old May 23, 2017 | 07:58 AM
Caddyshack's Avatar
Caddyshack
Or go the whole hog and get a Mountune or MK roller barrel throttle body for really good throttle response (According to Mr Shead)
Old May 23, 2017 | 08:51 AM
800bhp's Avatar
800bhp
**RS COSWORTH**
10 Year Member
Are the MK one a multi throttle bodies?
Old May 23, 2017 | 12:37 PM
martysmartie's Avatar
martysmartie
Yes (70 MM) I have known others using them as well.
Martin
Old May 23, 2017 | 05:36 PM
Caddyshack's Avatar
Caddyshack
He does both, large body in billet, also his own inlet OR Billet roller barrel inlet.
Old May 23, 2017 | 07:36 PM
800bhp's Avatar
800bhp
**RS COSWORTH**
10 Year Member
Thats just the 1 throttle body im after something like this.
Does he do anything like this?
Old May 23, 2017 | 08:14 PM
Caddyshack's Avatar
Caddyshack
Yes, as per my post, he does BOTH. I only had the pic of the single.
Old May 23, 2017 | 08:19 PM
costina's Avatar
costina
That looks like a jenvey set up.....
Old May 23, 2017 | 08:24 PM
800bhp's Avatar
800bhp
**RS COSWORTH**
10 Year Member
Yes thats a jenvey
Old May 23, 2017 | 08:36 PM
Caddyshack's Avatar
Caddyshack
Mountune do one too but I THINK it needs porting as was designed for WRC restricted cars.
Old May 23, 2017 | 08:44 PM
800bhp's Avatar
800bhp
**RS COSWORTH**
10 Year Member
There a difficult to get hold as you cant buy them new anymore I found 1 that was going on Rally car thats going over to Europe and didnt want to sell it.
Old May 24, 2017 | 08:06 AM
Caddyshack's Avatar
Caddyshack
I think Mark Walker will sell you one and I THINK he has one on the shelf and ready to go. 07753 440 553
Old May 24, 2017 | 09:08 AM
800bhp's Avatar
800bhp
**RS COSWORTH**
10 Year Member
Nice one for that should be having 1 fitted towards the end of the year. He's got what I've been looking for
