What throttle body upgrades are there for cossies using level 8 500bhp+?
Old 18-05-2017, 02:47 PM
forevaford
forevaford's Avatar
Default What throttle body upgrades are there for cossies using level 8 500bhp+?
As title really, I'm trying to remain my Std management, but always thought the throttle body looks small in these. It's a saph cossie gt3076 spec, also thinking about using the auto specialist inlet manifold. Just need bigger throttle body options please
Old 18-05-2017, 03:32 PM
Caddyshack
Caddyshack's Avatar
My car is near on 500bhp and the throttle body is standard. I have got the Hart manifold.
MK Motorsport and a few others do larger throttle bodies if needed. I have got a larger throttle body on the shelf but have not used it so far.
Old 18-05-2017, 03:46 PM
forevaford
forevaford's Avatar
It's just being able to use the Std tps ain't it. Not too fussed on the iscv but it would be nice to remain that as well
Old 18-05-2017, 03:56 PM
Caddyshack
Caddyshack's Avatar
Not sure where my bigger one came from originally but it too runs the standard TPS and has ISCV too.
With a bit of work you could get the TPS mounted on anything with a spindle on it.
Old 19-05-2017, 11:25 AM
Ridgey
Ridgey's Avatar
Aren't the RS500 throttles larger ?
Old 19-05-2017, 11:28 AM
costina
Live long and prosper!!
costina's Avatar
There is a guy on ebay who can mod the std body for a larger butterfly.
Cost about 100 quid.
Old 19-05-2017, 11:31 AM
costina
costina's Avatar
FORD SIERRA COSWORTH - GASFLOWED ANTI LAG THROTTLE BODY eBay
http://m.ebay.co.uk/itm/FORD-SIERRA-COSWORTH-GASFLOWED-ANTI-LAG-THROTTLE-BODY-/380297902926?nav=SEARCH
Old 19-05-2017, 12:49 PM
Caddyshack
Caddyshack's Avatar
That would do the job then!
Old 19-05-2017, 02:36 PM
costina
costina's Avatar
Thanks.
The link never seems to come out right for me.
Wonder what the std body will flow in terms of power.?
Old 21-05-2017, 07:02 PM
lee2cossies
lee2cossies's Avatar
Thanks.
Harvey told me that he's seen 700hp a few times on his engine dyno with a standard throttle body and there's no need to change unless going beyond that.
Old 21-05-2017, 07:06 PM
costina
costina's Avatar
Harvey has prob forgotten more stuff than most tuners/engine builders know.
I am sure the op will appreciate that info.......
lee2cossies (23-05-2017)
Old 22-05-2017, 12:23 AM
1374lee
1374lee's Avatar
yes I was also told a standard t/b will flow way over 500bhp. Some tuners advise change at around 550, I won't name them though.
Thanks. Lee.
Old 22-05-2017, 10:27 AM
Caddyshack
Caddyshack's Avatar
Thanks. Lee.
In theory they could flow up to 700bhp but actually be causing some restriction / heat etc..at 550bhp and therefore by removing the restriction with a larger body you improve the efficiency...therefore it doesn't hold the power back at 550 with no further gains until removed but could benefit in some way potentially.
Old 22-05-2017, 12:20 PM
ajamesc
cossie fan (unluckerly)
ajamesc's Avatar
When I had 500 I used a small turbo escort one sure mark said it gives better response there larger than the 2wd one
Old 22-05-2017, 08:24 PM
1374lee
1374lee's Avatar
Yep, Mark advised using the st escos t/b when I had my 3dr which was around the 500bhp figure.
Thanks. Lee.
Old 23-05-2017, 07:58 AM
Caddyshack
Caddyshack's Avatar
Or go the whole hog and get a Mountune or MK roller barrel throttle body for really good throttle response (According to Mr Shead)
Old 23-05-2017, 08:51 AM
800bhp
**RS COSWORTH**
800bhp's Avatar
Are the MK one a multi throttle bodies?
Old 23-05-2017, 12:37 PM
martysmartie
martysmartie's Avatar
Yes (70 MM) I have known others using them as well.
Martin
Old 23-05-2017, 05:36 PM
Caddyshack
Caddyshack's Avatar
He does both, large body in billet, also his own inlet OR Billet roller barrel inlet.
Old 23-05-2017, 07:36 PM
800bhp
**RS COSWORTH**
800bhp's Avatar
Thats just the 1 throttle body im after something like this.
Does he do anything like this?
Old 23-05-2017, 08:14 PM
Caddyshack
Caddyshack's Avatar
Yes, as per my post, he does BOTH. I only had the pic of the single.
800bhp (23-05-2017)
Old 23-05-2017, 08:19 PM
costina
costina's Avatar
That looks like a jenvey set up.....
Old 23-05-2017, 08:24 PM
800bhp
**RS COSWORTH**
800bhp's Avatar
Yes thats a jenvey
Old 23-05-2017, 08:36 PM
Caddyshack
Caddyshack's Avatar
Mountune do one too but I THINK it needs porting as was designed for WRC restricted cars.
Old 23-05-2017, 08:44 PM
800bhp
**RS COSWORTH**
800bhp's Avatar
There a difficult to get hold as you cant buy them new anymore I found 1 that was going on Rally car thats going over to Europe and didnt want to sell it.
Old 24-05-2017, 08:06 AM
Caddyshack
Caddyshack's Avatar
I think Mark Walker will sell you one and I THINK he has one on the shelf and ready to go. 07753 440 553
Old 24-05-2017, 09:08 AM
800bhp
**RS COSWORTH**
800bhp's Avatar
Nice one for that should be having 1 fitted towards the end of the year. He's got what I've been looking for
