focus airbag light reset ?
Old May 17, 2017 | 12:33 PM
steveo3002's Avatar
steveo3002
Default focus airbag light reset ?
i had to start our mk1 with the pasenger seat out , its obviously put the warning light on, the seat is back in the car
had a quick look on forscan and dont seem to be able to reset it
whats the procedure please?
Old May 17, 2017 | 10:32 PM
liam-rst's Avatar
liam-rst
shit happens
Have you tried disconnecting the battery for 10 mins?
Old May 17, 2017 | 10:33 PM
liam-rst's Avatar
liam-rst
shit happens
Also did you do the nut up on the plug tight enough?
Old May 19, 2017 | 04:58 PM
steveo3002's Avatar
steveo3002
it was the bolt
thanks
Old May 20, 2017 | 01:26 PM
liam-rst's Avatar
liam-rst
shit happens
Haha your welcome, easily overlooked
Old May 29, 2017 | 07:44 PM
Mashurst's Avatar
Mashurst
Have you fixed it yet Mate?
If not, I've been fiddling with forscan and my seat airbag lights, and re-setting has been quite easy. Juts click on the DTC button, select the code that needs re-setting, and click on the re-set button.
Problem with mine is that although I can re-set the codes, they just come back 'cause I haven't managed to find a solution for not having the bags
