please advise my on a turbo
Apr 10, 2005 | 08:57 PM
My engine specs:
EFI conversion (OFAB ecu)
stage 1 head
0.5mm oversized mahle pistons
kent 35 cam
beige injectors
ahmed bayjoo chip
pro alloy front mount intercooler
shall I go for a T3 hybrid (stage2 or 3 ?) or a T34 hybrid turbo ??
thanks
Apr 11, 2005 | 02:33 PM
Depends what power you want from it.
IMO go for a Stage 3 T3.
Apr 11, 2005 | 02:53 PM
Hi christian...what sort of power levels do you think a T34 is required? also what sort of RPM does the boost kick in?
bassboy
Apr 14, 2005 | 05:23 PM
280 plus for a t34. You need a very good cylinder head to support it too. You'll start producing boost at around 2700 with a stage 3 t3 - this is what i'd also recommend.
Apr 14, 2005 | 06:25 PM
what is the power limit of a STAGE 3 T3 ?
Apr 14, 2005 | 09:16 PM
Is it true that its a good idea to go for a stage2 if you want more power at
low-/mid range revs ?
Matt Baxter
Sep 16, 2015 08:30 PM
Bailes1992
Sep 3, 2015 02:17 PM
borboyous
Aug 22, 2015 11:17 AM
Bailes1992
Aug 16, 2015 07:14 PM
Michael Wisbey
Aug 14, 2015 11:57 PM
