Power upgrade
It looks like it's time for me to take my car back to have the map checked and adjusted so was thinking of upgrading the turbo at the same time to save on paying to be mapped twice.
Current spec
200 block with valve pockets machined in to pistons
Mild polish and ported head with ba16 inlet std exhaust vernier pulleys
T34/63 turbo holds 28psi. Air injector boost control
Pectel T2 management and loom.
The block wasn't long studded when built as wasn't going to run 400 + bhp but was fitted with ARP Stud and nut kit. A few people have said I can't run anymore power as will crack the block because of the ARP stud kit if I fitted a bigger turbo due to it trying to lift the head.
My question is can I change the turbo for say T38 or maybe a GT30 without any problems or am I stuck at the current power unless I strip the block and have it long studded.
Current spec
Current spec
Current spec
Are you on standard head bolts or the ARP stud kit. I was told the ARP kit doesn't stretch so pulls in the threads and cracks the block to which point I would rather stay at the current power rather than take the risk.
All "old fashioned" by todays standard but it still goes well and has plenty of get up and go!
The point I am trying to make is you can safely upgrade your power and still keep reliability.I have done a lot of miles in mine and its power gets well used but so far so good.
My advice to you would be talk to a Cosworth specialist, tell him what you want and what will be required to achieve it.
I'm currently running a standard T34/63 that is over due a rebuild or upgrade but what can I use that will be an improvement as seems an ideal time to do so but not wanting to crack my block due to being fitted with the ARP stud and nut kit
The car is more than quick enough at the moment but thought as the turbo needs looking at why not upgrade at the same time.
Was thinking of sticking with the T34/63 but having it converted to roller bearing and maybe a billet wheel if that's not going to risk cracking the block.
