Need to separate 2wd exhaust manifold - Scared!
Old Apr 21, 2017 | 12:16 PM
oto's Avatar
oto
Default Need to separate 2wd exhaust manifold - Scared!
Hi,
I'm fitting a stage 3 hybrid turbo in place of a smaller hybrid. I managed to get the old one off by unbolting it from the 'trousers'/secondary/upper manifold after having a massive faff disconnecting the coolant banjo at the back of it. The stage 3 has a larger compressor housing which now fouls on the head so I was thinking of separating the 2 piece manifold at the lower joint as it suggests in the Ford Workshop Manual. I've tried to slacken one of the bolts but it's tight.
Will the four 12-point bolts come out if I 'grow a pair' apply a bit more pressure or are they likely to shear leaving me with a hell of a job?
Thanks
Old Apr 21, 2017 | 02:17 PM
Sierrasideways's Avatar
Sierrasideways
They're about Ł80 for all 4 if you break them as they're inconel lol
http://shop.grahamgoode.com/primary-...38-71702-p.asp
Philip.
Old Apr 21, 2017 | 02:49 PM
costina's Avatar
costina
Live long and prosper!!
10mm 12 point socket required on 1/2 " drive. They might snap if they do use titaium bolts from ebay saves the cost of those original bolts.
Could always try a little heat.
Old Apr 22, 2017 | 12:12 AM
Toe Knee's Avatar
Toe Knee
What are the original ones made of our of interest?!
Old Apr 22, 2017 | 05:48 AM
oto's Avatar
oto
Inconel apparently.
Old Apr 23, 2017 | 11:30 AM
Cragrat's Avatar
Cragrat
sit boo boo sit
id heard it was Adamantium...
Old Apr 29, 2017 | 08:04 PM
oto's Avatar
oto
I chickened out and managed to fit the the turbo by removing all but one of the studs and prior fitting the coolant input pipe to it. After jiggling it into place and inserting the studs I used a crowsfoot spanner to torque the studs then fit the nuts. Awkward but successful.
Old Jun 28, 2017 | 01:36 PM
ossie cossie's Avatar
ossie cossie
What are these bolts like to remove if they snap off.
Old Jun 28, 2017 | 04:02 PM
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
Your thinking of wolverine
Old Jun 29, 2017 | 08:37 AM
cossynut2's Avatar
cossynut2
10 Year Member
That is what his super sharp claws are made of. Unfortunately it is not a real material!
