rear window regulators
What are you trying to do, are you retrofitting rear electric windows? And what do you mean with the window regulator? The electric motor and arm that moves the window up and down?
In that case (if I remember correctly) the motor is at the rear of the door and the arm is at the front. The motor/mechanism should have an L or R stamped on it to indicate for which door it is. I remember having difficulties finding the correct holes for the rivets when I retrofitted mine, but all holes are definately there.
I guess this is a retrofit the car I'm trying to fit the motors to had wind up regulators took those out to fit electric ones but can't find the correct position with the window up the arm is not in the runner and if I put it into the runner and lower the Window it can come completely down
If I remember correctly (quite a long time since I did this), the electric ones use only one hole the same as the manual one. The other 3 holes are different ones. Unfortunately I don't have a picture of which holes to use or how it is orientated inside the door.
Perhaps you have switched around the left and right mechanism? Or the arm needs to be at the rear of the motor instead of the front. But I am quite sure those 4 holes are the ones to use.
The manual mechanism is mounted on the (other) 4 holes on the flat rectangle, with the big hole in the middle for the winder.
