Ford KUGA Talk about the Ford Kuga here!
Puzzled
Old Mar 11, 2017 | 01:46 PM
AngryAnt's Avatar
AngryAnt
Default Puzzled
We have a kuga Mk1 with 33k on the clock.
A few mths ago the kuga wouldnt crank fully to start as though its tries to get there and then stops...
So we had the batterry chkd and replaced which seem to do thd trick then it happened over again.
So we had the fuel filter replaced again all ok....
The car cranks n starts not an issue.
The car runs ok aswell again no issues.
We have started to use esso diesel synergi plus instead of the supermarket offerings....
Anyway no issues.
A week today it happend again and all week the same it cranks but not quite get there to start after a few tries it eventually starts and all is ok...
Its only does this in a morning though after standing overnight..
When my missus finishes after a 10hr day its starts without an issue but left overnight it sometimes wont start...
Any ideas anybody....
Heres a brief video you may require earphones..
Old Mar 11, 2017 | 01:57 PM
H3lsing's Avatar
H3lsing
ffoc.co.uk
Any warning messages on the dash?
This might be of some help. Have a read of this: http://www.kugaownersclub.co.uk/foru...opic13873.html
Maybe it's a common problem with diesel kuga's?
Old Mar 11, 2017 | 02:26 PM
AngryAnt's Avatar
AngryAnt
Nothing.
Not even an error code....
Old Mar 11, 2017 | 02:35 PM
RichieST's Avatar
RichieST
When it fires is there much smoke out the exhaust? Does the glow plug light come on and go out with the ignition?
Old Mar 11, 2017 | 03:20 PM
AngryAnt's Avatar
AngryAnt
No glowplug light and nothing of note from the exhaust...
No white or blue smoke....
Old Mar 11, 2017 | 03:24 PM
AngryAnt's Avatar
AngryAnt
Thats interesting thanks for that info
Old Mar 11, 2017 | 05:51 PM
RichieST's Avatar
RichieST
I'd be concerned there is no glow plug light coming on. Maybe check the fuses for the glow plugs?
Old Mar 11, 2017 | 06:06 PM
AngryAnt's Avatar
AngryAnt
Should the glow plug light on the dash light up each time you start it.....
Old Mar 11, 2017 | 08:59 PM
RichieST's Avatar
RichieST
Yes, it should come on for 5 seconds or more when the engine is cold, bur you will only see it for a second or two when the engine is warm as it uses the engine temperature to determine glow plug operating time.
Old Mar 12, 2017 | 07:51 AM
AngryAnt's Avatar
AngryAnt
I sat there starting the kuga this morning and intentionally watched the dash as i started the kuga which by the way took 5 attempts..
No glowplug symbol showed at all........
So im begining to wonder if its the glowplug relay.......
If so do you know where it is located......
Old Mar 12, 2017 | 10:51 AM
AngryAnt's Avatar
AngryAnt
We nipped out this morning and i noticed that when we where starting up the kuga to come home the glow plug light briefly flashed up must have been for a split second while the kuga started as the engine would have been warm..
But i didnt notice the glow plug light first thing when it wouldnt start....
Old Mar 13, 2017 | 08:28 AM
AngryAnt's Avatar
AngryAnt
Hi to further our conversation i noticed that the glow plug coil icon lit up briefly at the start of the first attempt this morning....
It took 4 attempts to start today...
Also the glowplug coil icon didnt light up after the first attempt so for the next 3 attempts it didnt light up...
Old Mar 13, 2017 | 08:35 AM
RichieST's Avatar
RichieST
I would check for power at the glow plug rail when turning ignition on. If you don't have it then start investigating fuses / relays.
Old Mar 13, 2017 | 03:06 PM
AngryAnt's Avatar
AngryAnt
Booked in for a full dianostic chk later in the week ..
I will post the results.
Old Mar 14, 2017 | 08:31 AM
AngryAnt's Avatar
AngryAnt
Well this morning it started first time.....not unusual.
Only thing i did different was tap the start button and watch the glow plug coil briefly light up...
Tapped the start button again as to turn it off then tapped the start button again and no coil light at all..
The screen dash says push clutch and tap the start button and whoosh first time.....
Unbelievable.
Old Mar 22, 2017 | 09:42 AM
AngryAnt's Avatar
AngryAnt
Just to let you know the problems have gotten worse....
Yesterday while the missus was driving the kuga she slowed at the lights behind a motor and when she put he foot down to move the engine had switched off....
Its started instantly when she pressed the button though....
This morning i spent almost 20mins trying to start the kuga and all it does is crank and not fire up.....
So the missus got a lift to work....
Later i tried to have another go after a few attempts still wouldnt fire up after cranking...
So then i tried to lock the kuga and it wouldnt lock...
So ive most probably nailed the battery and the battery is only 6wks old aswell and the fuel filter is only 6wks old......
Any ideas
Now the central locking from the fob isnt wotking.....
Ive had to lick the car using the key.......
Old Mar 22, 2017 | 07:15 PM
H3lsing's Avatar
H3lsing
ffoc.co.uk
Did you get the diagnostic check done? If so did it reveal anything?
Old Mar 23, 2017 | 09:03 AM
AngryAnt's Avatar
AngryAnt
Nothing came up on the ford IDS.....
Now this morning when i tried again a couple of time this morning and still the same then i got ding ding ding ding.......power streering malfunction......
The the warning just vanished....
Old Mar 23, 2017 | 01:19 PM
AngryAnt's Avatar
AngryAnt
Ive have tried the motor again and i still cant use the fob but i can still use the key to get into the car....
On the small info screen this pic below briefly flashes up...
This image as started to briely show up any ideas why....
Old Mar 23, 2017 | 03:28 PM
AngryAnt's Avatar
AngryAnt
Apparently its the anti shudder valve or shutter valve cant remember which....
Old Mar 23, 2017 | 03:51 PM
AngryAnt's Avatar
AngryAnt
He chkd the fuel line all fuel of fuel..
His gizmo said fuel pressure was ok...
No fault codes so he made it have a fault code by unclipping a wire...
Then that gave hime a fault code..
Battery died..
Gave it a boost and got it running.....
Then it showed him the valve was working so that came to his conclusion its sticking..
In an awkward place aswell.....
Old Mar 25, 2017 | 12:12 PM
AngryAnt's Avatar
AngryAnt
Well had to call the RAC this morning as it was back to doing its usual antics....
After much deliberation and speaking to the missus and getting running is that the anti shudder valve is the culprit more so when the missus told him that the other day when she was out driving and stopped behind another car the engine had stopped..
That again give him the thought that the anti shudder valve is looking more n more likely...
So it is now with our mechanic he dismantle it all and throughly clean it and build it all back up......
Old Mar 29, 2017 | 06:30 PM
AngryAnt's Avatar
AngryAnt
The mechanic we use who by the way knows his stuff said the other day that the anti shudder valve was sticking....
Well he was correct and he found out why...
The anti shudder valve as a recess where the gasket/seal partcially sits in.
Well the previous owner must have had somebody look at the car and didnt site the gasket/seal properly hence it was spraying oil very finely like a mist...
And through that hole it was sucking in air....
So once the engine was warm during the day the gasket/seal was holding..
As it was sat over night and cooled down it just sucked air in hence a reason not to start..
The anti shudder valve was literally gunked up and wouldnt work properly...
A new seal as sorted it and a good clean of the valve..
Old Mar 29, 2017 | 06:34 PM
H3lsing's Avatar
H3lsing
ffoc.co.uk
It's nice to get to the bottom of problems like that. They just drive you demented until you do. I've had my fair share with my focus during the 5 years I've had her.
Old Mar 29, 2017 | 06:37 PM
RichieST's Avatar
RichieST
Glad it's sorted.
Tell me about it. My wife's newish cmax has been nothing but trouble. Got an error up on the dash today saying child lock malfunction. It's always one thing or another with a ford!
Old Mar 29, 2017 | 06:39 PM
AngryAnt's Avatar
AngryAnt
We had a fucus prior to the kuga bought it on 06 as it was 1yr old and 3k miles on the clock.
Never had an issue with it at all.
Always passed its mots etc and always serviced....
Old Mar 29, 2017 | 06:41 PM
AngryAnt's Avatar
AngryAnt
Just need to collect the spare fob from the dealer if he still as it as he as a few apparently in a box....
And then try n get this fob sorted......
Using the key at the moment..
Old Mar 30, 2017 | 07:43 AM
AngryAnt's Avatar
AngryAnt
Well this morning the kuga did the exactly the same crank n not start...
So as the rac guy showed her as you go through the start system to use the accellorater..
As she did and it started using the accelorator....
We have now noticed a metallic sounding noise in the area where the alternator and the belts are.....
But this metallic whirring noise is only audible when the foot is on the accelorator.....
Also there is a stronger smell of fumes from the exhust since the valve was sorted.....
Old Mar 30, 2017 | 04:38 PM
AngryAnt's Avatar
AngryAnt
Just been back to the mechanics..
After this morning performance...
He linked his system to the OBD and immediately got a fault code....
Never managed a fault code before unless it was a forced fault code.......
Fault Code P02FA..
That is the first fault code the kuga as shown..
So since the anti shudder assembly was distmantled and the valve cleaned it actually threw up the code this morning due etc its antics..
So its been reset.
Fingers crossed for the morning as its no fun at 4-30am and your motor is playing up..
Old Mar 31, 2017 | 07:17 AM
AngryAnt's Avatar
AngryAnt
Im happy to say that the kuga started this morning without any problems....
Old May 5, 2017 | 07:11 PM
AngryAnt's Avatar
AngryAnt
We finally got around to having the throttle removed today and i had taken the old one home..
I removed the cover from the valve and the seal was broken and had an inch missing just right where the oil was spraying upwards...
I then noticed that all the electrics and connections had oil in them thus probably causing the problem every now n then not immediately starting...
The throttle valve is made by continental and dies anybody know where i can purchase a new seal for the valve cover as its a strange shape..
