Driveshaft
Old Mar 5, 2017 | 02:44 PM
turbo1973's Avatar
turbo1973
Default Driveshaft
Can someome tell me if this is the right or wrong drive shaft same length but ends different
Old Mar 5, 2017 | 03:04 PM
Caddyshack's Avatar
Caddyshack
One is off an abs equipped car, the other is not so they are not the same. Is one a non abs xr4x4?
A bit more info like car etc is useful
You may be able to swap one shaft over to the other end.
Old Mar 5, 2017 | 03:06 PM
focusv8's Avatar
focusv8
The left hand one is for ABS, the right hand one isn't.
I'd guess the right hand is after-market, the left is genuine.
turbo1973's Avatar
turbo1973
Its fpr works van fiat scudo just replacing driveshaft
Old Mar 5, 2017 | 03:08 PM
turbo1973's Avatar
turbo1973
So its a non abs one they gave so will i need to get it changed
Caddyshack's Avatar
Caddyshack
What is wrong with the one that needs replacing? As said you may be able to build one in to the other
Old Mar 5, 2017 | 03:19 PM
turbo1973's Avatar
turbo1973
Just worn was getting juddering underload
Old Mar 5, 2017 | 03:29 PM
Caddyshack's Avatar
Caddyshack
Why not strip the old one apart and see what is worn, it could be the output cup on the diff. No harm in stripping the old one as you were going to scrap it anyway.
Old Mar 7, 2017 | 03:27 PM
stevieturbo's Avatar
stevieturbo
C**t
And does the van have ABS ?
Where did the new shaft appear from ?
