Bara big tooth box, 6 Deg beam & Gripper diff
Old Mar 1, 2017 | 01:33 PM
cutch's Avatar
cutch
Series 1 4x4 cossie
Default Bara big tooth box, 6 Deg beam & Gripper diff
Bara big tooth gearbox with
Uprated Vc 60Nm
1 x 3.9 Drop Gear
£3000
MK Motorsport Stage 2, 6 degree beam. Sold
Everything has done less than 1000 miles, and is in perfect condition, both are currently on my series 1 and can be viewed / heard / driven etc before taken out if needed. I'm going back to standard drivetrain.
7.5" Gripper Diff, bought new from Bara 1000miles ago with 3.6 crown wheel and pinion, I have had a 4.1 installed by Gears, and new seals were installed at the same time. I still have the 3.6 CW & P so it can be suited to road or track use. I have done one track day and a set up on rolling road with the 4.1 in it since fitting the 4.1. Currently still on my track car and will need removing.
Sold
Old Mar 1, 2017 | 01:36 PM
Caddyshack's Avatar
Caddyshack
Why don't you just mount the beam on rubber bushes where it meets the shell? I dont think the other parts transmit much NVH road noise etc?
I haven't noticed any clonks, vibration or more noise since changing to 6 degree but the handling and geo options are much better?
I understand on the box and diff....good price on the box too!
Old Mar 3, 2017 | 09:57 AM
Harryh24's Avatar
Harryh24
Hi is there a difference between the 6 degree beam ark usually does? As they are 1k new from him?
Thanks
Old Mar 3, 2017 | 01:46 PM
turbotrev's Avatar
turbotrev
Thanks
Thats what i was thinking tbh.
Are you open to offers on the rear beam?
Cheers Paul
Old Mar 3, 2017 | 07:23 PM
jamie's's Avatar
jamie's
At least you wont need to wait 6 months for your mk beam
Old Mar 3, 2017 | 10:19 PM
cutch's Avatar
cutch
Series 1 4x4 cossie
Beams sold thanks guys.
And MT is selling the beams for £1375 ??
http://mt-motorsport.com/marko/index...ur3m4lsko6ohu7
Old Mar 8, 2017 | 10:49 PM
cutch's Avatar
cutch
Series 1 4x4 cossie
Deposit taken on the diff
Old Mar 9, 2017 | 12:02 PM
Sierrasideways's Avatar
Sierrasideways
I have seen that. I wonder is that without supplying your own beam as exchange as it says "on stock ready to go" on their site?
Last edited by Sierrasideways; Mar 9, 2017 at 12:03 PM. Reason: iPhone autocorrect again and abloodygain!!!!!! :/
Old Mar 9, 2017 | 05:03 PM
cutch's Avatar
cutch
Series 1 4x4 cossie
I bought mine without supplying a beam and he sent it overnight. Can't fault mark, had loads from him over the years
Old Apr 3, 2017 | 09:15 PM
eel-roy-t5r's Avatar
eel-roy-t5r
would this box work with standard diffs or would they need changing to 3,9
Old Apr 4, 2017 | 06:45 AM
cutch's Avatar
cutch
Series 1 4x4 cossie
Std diff on the front and 3.9 on the rear.
Old Apr 4, 2017 | 07:37 PM
eel-roy-t5r
bit to much for me then atm bud cheers for the info
Old Apr 4, 2017 | 08:04 PM
Caddyshack's Avatar
Caddyshack
Or change the drop gears? They go well on 3.9's too. The cossie is way over geared as standard.
I have 3.9 and close ratio on 16 inch 45 profile tyres and it still does 160 at 8,000 rpm (not that I rev it that high)
