Forged pistons or am In in trouble?
Old Jan 31, 2017 | 09:22 PM
28psiCY's Avatar
28psiCY
Question Forged pistons or am In in trouble?
Anyone have an idea what type of pistons these are? I purchased these years ago from eBay and where advertised as an accralite forged pistons. Diameter is 81.5mm (1658cc) However I've never found accralites with that type of Crown. You can tell my the first and forth piston the centre has a higher ring than the rest of the piston.
The car is running omex management and 28psi,
Are these pistons up to it or am I gonna need an engine soon?
Attached Thumbnails Forged pistons or am In in trouble?-_20170201_001657.jpg
Old Feb 1, 2017 | 06:42 PM
essexRSTSouthend's Avatar
essexRSTSouthend
I can tell you straight away these aint standard. Going by the circle lift in the middle of the pistons gives this away.
Old Feb 1, 2017 | 09:31 PM
28psiCY's Avatar
28psiCY
I've looked at every accralite design piston for the cvh, and found nothing with a raised centre. You think are low compression forged pistons?
Old Feb 1, 2017 | 10:33 PM
essexRSTSouthend
The rs pistons are flat as standard. Unless someone has changed the pistons to another cast piston... that would be pointless of course. i will have a quick look for you
Old Feb 2, 2017 | 11:34 AM
colins2's Avatar
colins2
is that as far up as they come in the bore?
Old Feb 2, 2017 | 04:01 PM
28psiCY's Avatar
28psiCY
I believe so. Any ideas?
Old Feb 3, 2017 | 12:13 PM
colins2's Avatar
colins2
they look quite far down the block if it is at tdc, whats it like to drive laggy?
Old Feb 3, 2017 | 12:22 PM
28psiCY's Avatar
28psiCY
No lag at all. Pic might not be tdc. Just picking my brain if they are infact accralites low compression pistons. Car is working 2 bar and really hasn't been driven as it has been off the road for 12 years!
Old Feb 8, 2017 | 10:03 PM
essexRSTSouthend
I've had no luck sadly mate
Old Feb 15, 2017 | 10:08 PM
essexRSTSouthend
i was just on ebay and if you type in cvh rs turbo engine, listing from power engineering build is there and look like your pistons!
Old Feb 16, 2017 | 12:08 PM
28psiCY's Avatar
28psiCY
Had a look at the pistons you mentioned. Very similar, but my pistons centre that are raised are bang in the middle of the piston. The pistons on the picture look to have the raised bit towards the edge of the piston. What you think?
Old Feb 19, 2017 | 11:38 PM
essexRSTSouthend
True that. I know a guy who might know. So i should have answer later today for you
Old Feb 20, 2017 | 10:18 AM
28psiCY's Avatar
28psiCY
Thank you sir!
Old Feb 20, 2017 | 08:26 PM
Bransby's Avatar
Bransby
There acralite forge pistons mate. I have the same ones fitted to mine. Hope the pics help, you can see part of the word acralite under the pistons if you zoom in.
Old Feb 20, 2017 | 08:34 PM
28psiCY's Avatar
28psiCY
Thank God! Your a life saver mate. How much boost you recon they can handle without any problems?
Old Feb 20, 2017 | 08:52 PM
Bransby's Avatar
Bransby
No problem pal. And I'm unsure, you would have to ask one of these lads. I'm still on with restoring the RS at the min so mine haven't seen much hammer yet. I would think the conrods would be the weak point over the forge pistons, unless your using steel H section rods that is. These lads on here will be lot more clued up than me
Old Feb 20, 2017 | 08:57 PM
28psiCY's Avatar
28psiCY
Have burton rods, omex management, and cossie green injectors. Should be at around 28psi. Hope it doesn't go boom!! Thanks mate
