mk1 focus
hi, saw a relatively cheap mk1 3 door 1.6 on a local classified site,
http://www.maltapark.com/item.aspx?ItemID=5893232
and on separate listing, a duratec motor.
http://www.maltapark.com/item.aspx?ItemID=4558141
A combination which of course is quite tempting. what else does it need other than bigger brakes and a rear disc conversion?
Depends on what your plans for the engine are ? But an st170 will be cheaper stronger and have bigger brakes a better interior as standard and more power to start with.
The only advantage with the Duratec is slightly less weight out front.
Is the engine swap straightforward? Don't want to mod
You will also need engine loom, interior loom, ecu, full exhaust system, ancillaries and plumbing etc. Its not as easy as just drop it in as the 1.6 zetec-se is totally different to the zetec-e.
It was and it wasn't, the 170 and RS were badged Duratec, which was a marketing stunt, as essentially they were Zetec-E engines.
But to the question, as Richie says, there is so much difference between Zetec and Sigma.
Martin
Martin
