Ford Focus (All Models) This forum is for discussion of all things pertaining to the Ford Focus Range that doesnt belong in the seperate ST & RS sections..
mk1 focus
Old Jan 17, 2017 | 01:35 PM
fenejon's Avatar
fenejon
Default mk1 focus
hi, saw a relatively cheap mk1 3 door 1.6 on a local classified site,
http://www.maltapark.com/item.aspx?ItemID=5893232
and on separate listing, a duratec motor.
http://www.maltapark.com/item.aspx?ItemID=4558141
A combination which of course is quite tempting. what else does it need other than bigger brakes and a rear disc conversion?
Old Jan 17, 2017 | 08:12 PM
big_wasa's Avatar
big_wasa
Depends on what your plans for the engine are ? But an st170 will be cheaper stronger and have bigger brakes a better interior as standard and more power to start with.
The only advantage with the Duratec is slightly less weight out front.
Old Jan 17, 2017 | 08:19 PM
fenejon's Avatar
fenejon
Well you have to find an st though, I was lucky to find that 3door(bought new locally). The alternative is import a used one from you and pay exorbitant annual road tax!!
Is the engine swap straightforward? Don't want to mod
Old Jan 17, 2017 | 08:29 PM
RichieST's Avatar
RichieST
You will also need engine loom, interior loom, ecu, full exhaust system, ancillaries and plumbing etc. Its not as easy as just drop it in as the 1.6 zetec-se is totally different to the zetec-e.
Old Jan 17, 2017 | 08:32 PM
fenejon's Avatar
fenejon
The ad in the second link says it has all the stuff other than exhaust.
Old Jan 17, 2017 | 08:50 PM
big_wasa's Avatar
big_wasa
Still a lot of work as the Duratec he was never fitted to mk1 focus.
Old Jan 17, 2017 | 09:55 PM
martysmartie's Avatar
martysmartie
It was and it wasn't, the 170 and RS were badged Duratec, which was a marketing stunt, as essentially they were Zetec-E engines.
But to the question, as Richie says, there is so much difference between Zetec and Sigma.
Martin
Old Jan 18, 2017 | 09:00 AM
Rowe's Avatar
Rowe
Skint
it was..... granted not in the UK though
Old Jan 18, 2017 | 09:27 AM
fenejon's Avatar
fenejon
how about swapping this instead?
http://www.maltapark.com/item.aspx?ItemID=5882513
Old Jan 18, 2017 | 10:18 AM
big_wasa's Avatar
big_wasa
Nobody has owned up to getting one of these running on the oem ecu yet and you are looking at a LOT of cash for aftermarket.
Old Jan 18, 2017 | 10:24 AM
fenejon's Avatar
fenejon
It has the fiesta's own ecu and loom
Old Jan 18, 2017 | 12:05 PM
Rowe's Avatar
Rowe
Skint
this is what i'm planning for mine, with a SC GDI 4 ecu. Currently collecting parts for the conversion.
Old Jan 18, 2017 | 05:31 PM
big_wasa's Avatar
big_wasa
I would do your home work on that one.
