Ford Focus (All Models) This forum is for discussion of all things pertaining to the Ford Focus Range that doesnt belong in the seperate ST & RS sections..
How To Fix Or Replace ???
Old Dec 24, 2016 | 07:58 AM
FOCUS_DRIVER2001's Avatar
FOCUS_DRIVER2001
Exclamation How To Fix Or Replace ???
Hi People..... Marry Xmas..
How can I sort this out I have used 3 kinds of the best glues with no luck or it sticking down. The rubber bit as gone so in will not slot back in.
Thanks
Old Dec 24, 2016 | 08:06 AM
costina's Avatar
costina
Live long and prosper!!
Thanks
Best option is to replace. But something like upol tiger seal will bond it to the panel but you will need something like gaffer tape to hold it into position while it sets.
Old Dec 24, 2016 | 08:10 AM
FOCUS_DRIVER2001
Where can I get a new part from... I have used tape to help with no luck.. I thought tiger seal turns into rubber I may be wrong.
Old Dec 24, 2016 | 08:39 AM
focusv8's Avatar
focusv8
That's wrecked.
You'll never get it to stick flat, well you could if it was irreplaceable but would take time and care.
New one for Ford maybe or a breakers.
Or ebay, but it'll probably be cheaper to buy a door and remove the seal;
Similar to this?
http://www.ebay.co.uk/itm/Ford-Focus...wAAOSwYIxX-N12
Old Dec 24, 2016 | 08:58 AM
FOCUS_DRIVER2001
So can it not be fixed or replace.
Old Dec 24, 2016 | 09:51 AM
focusv8's Avatar
focusv8
Fixed, NO
Replaced , YES
Old Dec 24, 2016 | 09:55 AM
FOCUS_DRIVER2001
So how and where can I get a replacement.. What is the part called.. Thx
Old Dec 24, 2016 | 10:19 AM
Caddyshack's Avatar
Caddyshack
I would use tiger seal, warm the part first and key the surface then tape it in place and consider something like bamboo against a garage wall to hold it in place for 48 hrs to dry.
Old Dec 24, 2016 | 11:32 AM
STeve's Avatar
Super Moderator
bin it as its rotten, just buy new outer door glass weatherstrip, I have them but dont post as they bend like fook
