Garage / Workshop & Tools Section. Given working on your pride and joy is often one of the reasons cited for owning a Ford, post all your garage and tool collection pictures and questions in here.
what size compressor for home use?
Old Dec 11, 2016 | 04:59 PM
Fil's Avatar
Fil
ELASTIC BAND
Default what size compressor for home use?
looking at the good old mine field called ebay
what sort of 240v size one will i need for say using,
impact gun, air sander, grinder tools?
cheers
Old Dec 11, 2016 | 05:05 PM
costina's Avatar
costina
Live long and prosper!!
cheers
Fil
I used a 14cfm 3hp with a 50litre tank since 1998 which has been fine for all of the above. Its just gone bang (needs a new motor) so i have replaced it.
Old Dec 11, 2016 | 07:07 PM
gcfcos's Avatar
gcfcos
I've had a 50 litre one but couldn't keep up with my 3" Sander but coped with everything else including air guns etc. The next one I'm getting is a 100 litre one.
Old Dec 11, 2016 | 07:10 PM
mk1turboestate's Avatar
mk1turboestate
I have a 100 litre 3hp one and it seems to work with everything I use,
Old Dec 11, 2016 | 07:14 PM
mk1turboestate
This is what I have
https://www.machinemart.co.uk/p/clar...e-air-compres/
Old Dec 11, 2016 | 07:15 PM
costina's Avatar
costina
The CFM is the key. The higher the better 3hp motor is the max on a 13plug.
My new one is on a 16amp plug with a really large supply to the garage.
Old Dec 12, 2016 | 04:41 PM
mpilk's Avatar
mpilk
go for 100ltr one i have a 50ltr one and the sander uses a lot of air
Old Dec 12, 2016 | 05:20 PM
Fil's Avatar
Fil
ELASTIC BAND
cheers people got an idea to go on
3hp 50L min, but 100L would be better, tho the 50L would probably fit better for storage
will probably go secondhand, so if not up to my requirments , can shift it on will little loss
Old Dec 12, 2016 | 05:52 PM
costina's Avatar
costina
You have whatsapp message.
Old Feb 11, 2017 | 09:46 PM
ray barker's Avatar
ray barker
go for a 250 ltr they sound bigger than what they are. 50ltr ones are good for air tools but want keep up a orbital sander or windy grinder if you use them, the 250 does nearly everything. if your not using the latter 50/100 is good
Old Feb 15, 2017 | 10:31 PM
Turbo Zetec's Avatar
Turbo Zetec
Engine Machinist
i have a couple of cheap ones working together. i have a 50l sealey one and a 25l clarke one. between them both they can just about keep up with my die grinder, they're pretty noisy though
