Zetec running cold.
Old Nov 22, 2016 | 06:07 PM
Chopshop85's Avatar
Chopshop85
Default Zetec running cold.
Thanks to my new alloy radiator purchased this summer the temps on my zetec turbo have been perfect. However, now the cold weather is settling in my running temps are between 75-80 degrees.
Is this too cold?
Old Nov 22, 2016 | 07:44 PM
Giorgos92's Avatar
Giorgos92
What is your running temp during city driving? Is it the same or bouncing back to normal? If it goes to normal your thermostat might be stuck partially open
Old Nov 22, 2016 | 09:56 PM
Chopshop85's Avatar
Chopshop85
If I put the car through it's paces I can get it to increase to around 85-90. However when I stop boosting it will sit around 75-80 again.
This is mointered through a VDO temperature gauge mounted before the thermostat.
Old Dec 31, 2016 | 12:19 AM
Giorgos92's Avatar
Giorgos92
So even when sitting in traffic your temps are sitting around 75-80? Do your fans kick in at that temp?
Old Dec 31, 2016 | 12:31 AM
Chopshop85's Avatar
Chopshop85
Turns out the gauge isn't the most accurate. It is sometimes 5-10 degree's out.
Had it checked against the managements engine temp sensor.
Old Dec 31, 2016 | 08:01 PM
studabear's Avatar
studabear
I want a accurate gauge, might have to be a stack unit.
Old Jan 1, 2017 | 12:06 PM
Chopshop85's Avatar
Chopshop85
I dont know whether its the gauge or the sensor or both. In saying that there is nothing to say the managment temp sensor is 100% either.
Old Jan 10, 2017 | 12:58 PM
chalkey's Avatar
chalkey
rst junkie
My zetec turbo runs cold in this weather also, only way to sort it is block part of the rad off with some plastic ect, on a zetec turbo, running cold is a nice problem to have trust me lol
