St170 not starting after cambelt change
Old Nov 20, 2016 | 01:52 PM
Andy77walker's Avatar
Andy77walker
Default St170 not starting after cambelt change
Hi
So after replacing a failed cam belt, I'm having a bit of a problem with my ST170.
Yesterday when I re adjusted the timing, it started first time with the rocker cover off. Today when tried to start it with everything back on it won't fire up.
I've done two turns on the crankshaft and the tool slots in the cams perfect. The only thing that seems to be different is plugging in vtc solenoid . Would a knackered solenoid cause the car not to start?
Thanks guy's
Andy
Old Nov 20, 2016 | 02:58 PM
Andy77walker
UPDATE......
Got it started, but struggles at low revs. I'm pretty sure that the timing is correct. Anybody got any suggestions on where I go from here?
Old Nov 20, 2016 | 04:22 PM
studabear's Avatar
studabear
It's probably got bent valves if the belt snapped. Compression test would be a good idea.
Old Nov 20, 2016 | 06:43 PM
j6kyt's Avatar
j6kyt
did the original belt snap
Old Nov 20, 2016 | 07:23 PM
Andy77walker
I really hope it's not bent valves. Seems better at higher higher revs. I will be getting myself a compression tester tomorrow.
Thanks mate
Old Nov 20, 2016 | 07:27 PM
Andy77walker
The cambelt didn't exactly snap. The bottom pulley stripped the teeth from the belt
Old Nov 20, 2016 | 08:12 PM
j6kyt's Avatar
j6kyt
did you pin the crank in position and slot the bar in the cams then recheck after tightening everything. if so then a compression test is in order as stripped teeth puts timing out with risk of bent valves.
Old Nov 20, 2016 | 08:42 PM
Andy77walker
Yes mate, I've done all of the above. Ordered a compression tester, got to wait for it to turn up.
Does anyone know about the vtc? Could I have disturbed something there or maybe the solonid?
Any suggestions would be appreciated
Thanks
