St170 Timing tool help!!!
Old Nov 13, 2016 | 07:44 PM
Andy77walker's Avatar
Andy77walker
Lightbulb St170 Timing tool help!!!
Hi guy's
The timing belt failed on my 52 plate st170.
So I bought this timing tool http://www.ebay.co.uk/itm/281921495649 . but the bar that slots into the end of the cams won't fit in.
Every guide I can find the tool just slots In the grooves, but the cams sit just below the casing so the tool won't slide in
Any advice on how to make sure one cam isn't 180° out would be great too
Thanks
Old Nov 14, 2016 | 05:07 AM
haz87's Avatar
haz87
Rotate the cams another 180degrees. They are offset slots
Old Nov 14, 2016 | 07:51 AM
Andy77walker
Thanks a lot haz87.
The tool goes straight in
Also, do I have loosen off the cam pulleys or can it be done without undoing them
Thanks guy's
Old Nov 14, 2016 | 08:18 AM
haz87's Avatar
haz87
Easy mistake!
If there is slack in the belt between the two pulleys, then they will need to be loosened off to take up the belt slack. If its all tight between the two then no need.
Old Nov 14, 2016 | 08:46 AM
Andy77walker
Cheers haz87 for the quick response.
Just popping out between the showers to work on her
Old Nov 14, 2016 | 10:24 AM
studabear's Avatar
studabear
Have you had the engine in bits or are you putting a new belt on in the hope its not bent all the valves?
Old Nov 14, 2016 | 10:33 AM
STeve's Avatar
Super Moderator
sound advice from haz
Old Nov 14, 2016 | 11:12 AM
pyle's Avatar
pyle
I couldn't help but notice the ad says duratec engine. The st170 engine is a slightly tuned version of the zetec 2.0.
Old Nov 16, 2016 | 06:55 PM
Andy77walker
Hi mate, not had the engine in pieces. I was just hoping for the best to be honest. But look out for my new post ST170 running lumpy after cambelt change
Old Nov 16, 2016 | 07:05 PM
Andy77walker
It's definitely a duratec bud it says it on the engine cover. But i think you a right about it being a tuned version of the zetec
Old Nov 17, 2016 | 03:30 PM
pyle's Avatar
pyle
Yes it is the tools will not work. The is just badged as a Duratec... Don't know why they did that it has nothing even similar to the design of the Duratec
Old Nov 19, 2016 | 08:27 PM
Andy77walker
All done mate. As haz said, I had the cams 180° out, So the grooves were at the bottom. The tool worked perfectly.
The first time I did it, I must have moved the bottom cam because it was running very rough. Redone it today, and it started straight away
First time for me so quite pleased
