Turning zetec bottom end by hand
Old Oct 15, 2016 | 06:20 PM
demolition_man's Avatar
demolition_man
Default Turning zetec bottom end by hand
Hi guys,
I'm putting together a new zetec bottom end and after getting it all together I've noticed that turning the crank with a spanner is significantly more difficult at 90 degrees away from TDC. Is this normal or could it be that the pistons / rings are tight in the middle of the bores?
Its still fairly easy to turn, but I expected it to be one smooth motion. At the time it is more difficult to turn, I can hear what sounds like friction from the piston rings.
Any advice appreciated
thanks
Old Oct 17, 2016 | 09:08 AM
demolition_man
For anyone's future information, I've researched this and apparently it's perfectly normal
james kiely
18
Jan 29, 2017 03:23 PM
Cauf61
Escort Range
Oct 14, 2016 05:47 PM
zombie1965
Ford Mondeo Including ST
Oct 12, 2016 11:14 AM
Brocker
29
Oct 5, 2016 06:39 AM
