Ford Focus ST225 (MK2) 2005-2010 Everything relating to the Mk2 ST225 preface & facelift versions from 2005 to 2010
Focus ST 225 boost problem
Old Sep 24, 2016 | 11:17 AM
kubabiki's Avatar
kubabiki
Unhappy Focus ST 225 boost problem
Hello everyone,
I have strange problem with my car. It boost only about 0.3 bar but if you try to accelerate few times "unlock the car" it will get full boost and problem disappear until I turn off the car. For example I turn on the car, have no boost but try to accelerate few times then have boost and I can drive it for an hour without any problem. Then I stop the car, turn it off then turn on and problem appear again. It's really strange and it looks like electronic problem. I changed boost selenoid and there is no difference. I also changed MAF because of check engine and esp but I suppose it was different problem in the same time. Now I don't have any errors on computer. Hoses are ok. I spend few hours with my mechanic but only idea is to update software in the car in Ford service (I have stock ST). Any ideas?
Old Sep 24, 2016 | 05:39 PM
Dal_'s Avatar
Dal_
The most common problem is that your boost solenoid is acting up.
Old Sep 25, 2016 | 09:01 AM
kubabiki's Avatar
kubabiki
I tested my car on four different boost selenoids (mine stock, other stock, new one which I have now and another one) so it's not the cause of the problem...
Cauf61
Sep 4, 2016 07:03 PM
parky405
Escort Range
Aug 14, 2016 08:20 PM
rs cab
Aug 12, 2016 12:59 PM
willhosford
Aug 9, 2016 09:23 PM
3doorcozmess
Aug 2, 2016 09:52 PM
