Fuel pressure dropping off
Old Sep 16, 2016 | 03:00 PM
martin murrell's Avatar
martin murrell
Default Fuel pressure dropping off
Can anyone help. The fuel pressure drops after 10-15mins of driving from 41psi to 18psi. Got battery voltage at pump. I've fitted another Bosch 023 pump. Fitted new fuel filter
Old Sep 16, 2016 | 03:13 PM
haz87's Avatar
haz87
You dont say what car, but sounds like the regulator is fecked
Old Sep 16, 2016 | 03:19 PM
martin murrell
It's an escort cosworth with RS500 inlet and regulator
Old Sep 16, 2016 | 11:02 PM
stevieturbo's Avatar
stevieturbo
C**t
So presumably the car also stops after this happens ?
Because if it really is happening, it would be driving like fuck all.
Old Sep 17, 2016 | 07:26 AM
martin murrell
Unable to accelerate. Only way to drive is to just rest foot on accelerator. If you lift off fuel pressure increase but as soon as put foot on peddle pressure drops.
Old Sep 17, 2016 | 08:23 AM
mattxr3i's Avatar
mattxr3i
Could be the fuel filler cap failing to vent the fuel tank - could try loosening and re-trying.
When filling with fuel do you get a large "Whoosh" noise?
Old Sep 17, 2016 | 08:44 AM
stevieturbo
C**t
Tank vent/breathing is very possible. As above try leaving the cap loose and driving for a bit.
It sounds unlikely to be a regulator from the description.
Old Sep 17, 2016 | 02:35 PM
grcossie's Avatar
grcossie
A mate had this on a Sierra, it was something bloking inside fuelline from tank
Old Sep 17, 2016 | 02:42 PM
stevieturbo
C**t
Is the car used regularly ?
Old Sep 17, 2016 | 03:18 PM
costina's Avatar
costina
Live long and prosper!!
Sounds like a dodgy gauge to me otherwise it would not drive well as you have said.
Old Sep 17, 2016 | 03:26 PM
stevieturbo
C**t
He replied, it doesnt drive right
Old Sep 17, 2016 | 03:27 PM
costina's Avatar
costina
Bloody phones.....
Old Sep 18, 2016 | 08:48 AM
martin murrell
I've undone the fuel filler cap when it's happening and it's not a breather problem.
It's a track day car with fuel lines inside. I've put a fuel pressure gauge in the feed pipe at the fuel rail and it's not a blockage in the feed pipe. It's happening when you put your foot on the accelerator and you get that anitial vacuum in the inlet
Old Sep 18, 2016 | 09:06 AM
stevieturbo
C**t
Initially you said this problem happened after 10-15 mins of driving.
Now you're saying it happens only when you put your foot on the accelerator ? So is it a momentary loss of pressure or a constant loss of pressure ?
Details seem to be misleading.
Old Sep 18, 2016 | 01:21 PM
martin murrell
It's constant. Same fault if light throttle or heavy throttle.
Old Sep 18, 2016 | 05:53 PM
stevieturbo
C**t
Fuel pressure should track manifold pressure. Are you saying this never happens ?
If you test the reg and apply pressure, does fuel pressure do what it's supposed to do ?
ie fairly closely 1:1 track manifold pressure
Old Sep 19, 2016 | 12:35 PM
martin murrell
I've got a vacuum/pressure tester at work. I'll try it tonight.
Old Oct 2, 2016 | 01:22 PM
martin murrell
So I pulled a vacuum on the fuel pressure regulator and the fuel pressure dropped to 41 psi, and then put a pressure of 14psi and the fuel pressure went up to 61psi
Old Oct 2, 2016 | 05:06 PM
stevieturbo
C**t
Regulator has some ability to work fine then
blockage in the fuel tank does sound reasonable.
Old Oct 2, 2016 | 06:08 PM
martin murrell
I've had the pump out of tant several times and all looks clean and nothing blocking bottom of pump.
Old Oct 2, 2016 | 06:11 PM
stevieturbo
C**t
Did you try it with the filler cap loose ?
Old Oct 2, 2016 | 06:47 PM
martin murrell
Yes tried it with cap off.
Old Oct 2, 2016 | 07:02 PM
stevieturbo
C**t
You're going to need to do some proper testing.
Monitor both pump voltage and current draw, as close to the pump as possible. This will at least give some clues as to how hard the pump is working and whether the power supply is holding up during this problem.
And also while monitoring pressure as close to the reg as possible
or you could just change the reg...as it seems about the only major item you have not changed ?
Has the problem just happened suddenly, or what ?
Old Oct 3, 2016 | 12:28 PM
martin murrell
Ok I'll check those. It's only just started.
AndyStarks
Escort Range
Dec 29, 2016 10:14 PM
Shaunc
Sep 14, 2016 05:50 PM
JoeyBoyden
Sep 12, 2016 12:18 PM
Bob Breeze
Ford Mondeo Including ST
Sep 10, 2016 08:11 AM
siscossie
Sep 2, 2016 07:16 AM
