Couple of questions about cossie problems
Old Sep 13, 2016 | 05:23 PM
baz walton's Avatar
baz walton
Rock Out!!
Default Couple of questions about cossie problems
Hi all, I'm over in the restorations section trying to get my old girl sorted out.
(oldest rally Sierra time for some tlc)
Just a couple of quick questions that hopefully someone can help with.
The clutch has stuck to the fly wheel with sitting for awhile.
Would holding the brakes and turning the crank by hand (socket on the crank bolt) damage anything before the plate snapped free?
Or would it be better to wait until I try turning her over and use the starter to try and break it off?
The other question concerns the injectors.
They are greys and when I first got the car she ran badly and hunted until it was suggested that the pintle ends were cut off as they 'trapped fuel' I did this and she did run well afterwards.
After the rebuild a couple of years ago she wouldn't run properly.
The fuel lines were changed, the tank cleaned out and the injectors cleaned. She then ran and pulled well.
A couple of trips later she began to miss and then wouldn't run at all.
I asked injectortune to check the plugs they had cleaned and they said they were still fine.
Once I've cleaned out the lines again, she has clean fuel in, cleaned plugs and a new batt. I'll test to see if she runs, but is it possible that the uncut injector pintles could be causing her to run rich and stop?
The greys with the new ends on them..
Looking at the plugs it looks like she was very rich on 134, but 2 looks like it just didnt fire at all after the new plugs were put in.
So, I maybe barking up the wrong tree with the pintles, it may be electrical?
And thanks in advance for any help that might point me in the right direction.
Old Sep 13, 2016 | 05:35 PM
costina's Avatar
costina
Live long and prosper!!
Typical greys on a poor map or just starting and shunting about causing fouled plugs.
As for clutch jack up rear on stands get it running with the wheels turning stamp on the brakes should brake free.
Old Sep 13, 2016 | 06:36 PM
baz walton's Avatar
baz walton
Rock Out!!
Cheers Costina.
Was first part of your answer a statement or question?
Old Sep 13, 2016 | 07:52 PM
costina's Avatar
costina
Originally Posted by baz walton
Cheers Costina.
Bit of both really. greys can overfuel if not mapped correctly and also if engine started for short periods and not left to warm up and be driven if will foul plugs.
Old Sep 16, 2016 | 11:20 AM
The Youth.'s Avatar
The Youth.
what plugs are they?
how did the garage come to the conclusion the plugs were fine?
Steve
Old Sep 17, 2016 | 03:19 PM
baz walton's Avatar
baz walton
Rock Out!!
Hi 'the Youth'
The plugs were spotless when they came back from injectortune. They were so0tted up after a few runs and then (as mentioned) only being used to try to find the fault.
I havn't got the plugs with me, so cant say yet what type, but they were the same type as she has always had.
Old Sep 18, 2016 | 12:42 PM
stevieturbo's Avatar
stevieturbo
C**t
Those plugs are scrap, replace them
If jerking the clutch free does not work as described above, then you will need to access the clutch/flywheel area.
Get someone to press the clutch pedal down and if you can poke a thin screwdriver up in and try and prise the friction disc away from whichever surface it is stuck to. It shouldnt take very much effort, although you may need to rotate the engine manually and do this in a few spots to get it to break free.
Old Sep 18, 2016 | 01:49 PM
costina's Avatar
costina
Are those plugs pp8's or 071's ?
Steve said bin those and i would agree they are cheap to buy.
Old Sep 23, 2016 | 07:12 PM
baz walton's Avatar
baz walton
Rock Out!!
Sorry for late reply, I didn't see there had been posts.
I'll be sorting new plugs shortly along with oils etc.
The clutch is now free, I pulled the box to free it and to clean underneath.
I have found one possible culprit for her woes, the earth strap from the body to the back of the power steering bracket was loose (couldn't see it, it just moved as I brushed past it)
I'm sure the engine not earthing to the shell would cause faults?
Old Sep 23, 2016 | 07:14 PM
stevieturbo
C**t
It certainly wouldnt help.
Old Sep 23, 2016 | 07:18 PM
baz walton's Avatar
baz walton
Rock Out!!
Hahah, yes adding the question mark did make me seem like a dimwit.
I knew when I saw it it would be causing faults, I was just asking if if a lack of/ or intermittent earth would cause a particular one, like a sensor not reading correctly or the injectors not being able to fire.
Old Sep 23, 2016 | 07:27 PM
stevieturbo
C**t
It could cause all manner of faults, you just couldnt say anything specific.
And it could cause an even bigger fault that if the engine is not earthed correctly...when you try and start the car and the starter needs a substantial earth path in order to function....it can try and pull it from anywhere else and cause all sorts of damage.
Old Sep 23, 2016 | 08:44 PM
baz walton's Avatar
baz walton
Rock Out!!
Fingers crossed it hasn't fried anything.
Old Sep 24, 2016 | 08:36 AM
london_chris's Avatar
london_chris
those pintle caps deffo need the end cutting off
Old Oct 26, 2016 | 07:35 PM
baz walton's Avatar
baz walton
Rock Out!!
Found the problems. The crank pully had rust on the lugs. The crank sensor was corroded.
Cleaned one, changed the other.
She now runs.. On 3 cylinders, as the coil pack is toast. Haha, it never ends, but we're getting there.
(Oh, fortunately the lack of earth dosn't seem to have damaged anything).
jonesmj
Aug 3, 2016 09:39 AM
Michael Dunne
Jul 28, 2016 03:09 PM
Michael Dunne
Jul 22, 2016 07:30 PM
HmmDK
Jul 17, 2016 04:42 PM
paceo
Jul 12, 2016 11:07 PM
