St170 remap
Old Sep 4, 2016 | 12:08 PM
Sportsilva's Avatar
Sportsilva
Default St170 remap
I think I need a custom remap.atm I'm still using bluefin but with all the changes on my ST I don't think the bluefin is helping anymore.my mods are.
Retarded exhaust cam( 1 tooth on the original pulley)
Induction
Decat
Msd coilpack.
Advice needed...
Btw in from Oxfordshire UK
Old Sep 7, 2016 | 08:58 AM
Rowe's Avatar
Rowe
Skint
Induction
Decat
Msd coilpack.
Advice needed...
Jamsport can write you a custom map. It'll be around 450 quid though.
Dreamscience can make slight tweaks to their off the shelf map too iirc. Best thing to do is contact Carl for confirmation
Old Sep 7, 2016 | 09:07 AM
STeve's Avatar
Super Moderator
I would not go near jamsport with a enemys car as I have seen first hand some of their major very expensive cock ups , bluefin is a learning program but if you want a spot on map tailored to your car then you need a live remap not a plug and play thing, only a few specialist companys around that are very good like MSD at blackpool or pumaspeed/superchips have a good rep too with the 170, heard poor things about dreamscience and their over optimistic rolling road figures lets say as they are better known for the mk2 st/rs
Old Sep 7, 2016 | 10:09 AM
Rob Longson's Avatar
Rob Longson
Induction
Decat
Msd coilpack.
Advice needed...
rather curious as to what Retarded exhaust cam is and what it does...
are there any decent mods we can do to an ST170
Old Sep 7, 2016 | 10:10 AM
Sportsilva's Avatar
Sportsilva
Originally Posted by 1-PD
I would not go near jamsport with a enemys car as I have seen first hand some of their major very expensive cock ups , bluefin is a learning program but if you want a spot on map tailored to your car then you need a live remap not a plug and play thing, only a few specialist companys around that are very good like MSD at blackpool or pumaspeed/superships have a good rep too with the 170, heard poor things about dreamscience and their over optimistic rolling road figures lets say as they are better known for the mk2 st/rs
Thank you for the reply.i think the car can do much better with the right map. Until then the factory map may be the best?
Btw my detonation problem was sorted with normal Cooper spark plugs =)
Better forget about iridium or platinum
Old Sep 7, 2016 | 10:12 AM
STeve's Avatar
Super Moderator
I have just had my vct deleted and kent fast road cams installed and with my other mods it has given me around 205hp which im fine with as its without going silly on a supercharger or turbo
Old Sep 7, 2016 | 11:49 AM
Rowe's Avatar
Rowe
Skint
a retarded exhaust cam is exactly what it says really. Standard exhaust cam timing gives the move driveable results for every day driving. By retarding it 1 tooth (rouhgly 8 degrees) it allows the motor to perform better high up the rev range.
It isn't something i'd do to a road car, because you may notice less power lower down the rev range. Obviously if it's a track car which is always in the high revs..... it's a decent mod
Old Sep 7, 2016 | 11:50 AM
Rowe's Avatar
Rowe
Skint
I have just had my vvt deleted and kent fast road cams installed and with my other mods it has given me around 205hp which im fine with as its without going silly on a supercharger or turbo
what other mods do you have? seems a healthy figure that does!
i'd say mine is around 150 or so........ it is almost identical down the straights compared to my friends ST150
Old Sep 7, 2016 | 12:03 PM
STeve's Avatar
Super Moderator
cfm larger throttle body, uprated injectors and pump, msd ignition with magnecors, scorpion sports cat with full ss system, 2nd cold air feed, remap, kent cams , vernier pulleys with vct delete, uprated oil pump and filters, high flow water pump, at moment its on a stock clutch but if it ever packs up I will bung on a solid flywheel but no point in doing that at moment as its very good, but for me I want the engine looking stock so a 35hp gain im happy with
Old Sep 7, 2016 | 12:28 PM
_Jimmy_'s Avatar
_Jimmy_
Can a live map be done with the standard ECU?
Old Sep 7, 2016 | 12:48 PM
STeve's Avatar
Super Moderator
the right people can do anything jimmy
Old Sep 7, 2016 | 01:57 PM
Rowe's Avatar
Rowe
Skint
cfm larger throttle body, uprated injectors and pump, msd ignition with magnecors, scorpion sports cat with full ss system, 2nd cold air feed, remap, kent cams , vernier pulleys with vvt delete, uprated oil pump and filters, high flow water pump, at moment its on a stock clutch but if it ever packs up I will bung on a solid flywheel but no point in doing that at moment as its very good, but for me I want the engine looking stock so a 35hp gain im happy with
That's really impressive. I'm slightly envious too!
I was hoping to stick with the vvt system, but I guess it doesn't really make any odds to me with it not being a road car
Where did your remap? I'm assuming they set your cams up too?
Sorry for the post hijack aswell OP
Old Sep 7, 2016 | 03:05 PM
STeve's Avatar
Super Moderator
most of the parts came from burton racing & cfm in the states and a buddy of mine fitted it all then mapped it and then we took it along to a decent dyno dynamics RR for a few runs to tweek it while running on their dyno it did peak slightly higher but he backed it down to 205 as it ran smoother and more suited for me
Old Sep 7, 2016 | 04:00 PM
Rowe's Avatar
Rowe
Skint
You're very fortunate your friend can map. I can do the mechanical work myself, but nowadays as nobody is really interested mapping them. Collins is pretty close to me, but I can't imagine that being very cheap.
I assume you're still running all the standard inlet and imrc?
Old Sep 7, 2016 | 05:53 PM
STeve's Avatar
Super Moderator
you assume right its the old saying if its not broke then dont fix it my buddy used to work at a tuning company where he picked up his skills but he builds cars for fun thesedays
Old Sep 7, 2016 | 06:19 PM
Sportsilva's Avatar
Sportsilva
To be honest with you bud...I was expecting more of the exhaust cam.
Old Sep 12, 2016 | 01:32 PM
pyle's Avatar
pyle
When doing a remap can the VVT be altered with the stock ECU?
Old Sep 12, 2016 | 03:30 PM
mcst's Avatar
mcst
Impressive results!
Clearly these have come a long way. 5+ years ago people were getting less than 5hp from the exhaust cam, bluefin, exhaust, filter etc...back then that was probably Ł2k+ Work. A lot of cash for little gain.
Old Sep 18, 2016 | 09:42 AM
Sportsilva's Avatar
Sportsilva
Just learned that 1 tooth is too much...but the car gets so much better with a 2.5"decat. (I was using and empty cat) and if allow some space between the MAF and the filter you will see some results.sounds silly I know but try.
Old Sep 18, 2016 | 06:03 PM
STeve's Avatar
Super Moderator
decat is only effective if proffesionally mapped in by a tuner, otherwise it saps power and gives you back noise
Old Sep 18, 2016 | 07:44 PM
Rowe's Avatar
Rowe
Skint
Who's told you this? Am curious like
Old Sep 19, 2016 | 06:41 AM
Sportsilva's Avatar
Sportsilva
No one did bud...done things myself and now car is much better.
Old Sep 19, 2016 | 06:42 AM
Sportsilva's Avatar
Sportsilva
I'm using bluefin tune 3. But belive me the car feels so much better.
Old Sep 19, 2016 | 06:51 AM
Rowe's Avatar
Rowe
Skint
whats your reason for changing the MAF position?...... or have i misunderstood you?
Old Sep 19, 2016 | 07:27 AM
pyle's Avatar
pyle
Probably sth to do with velocity, when the MAF is closer to the TB..
Maximas
Jun 6, 2016 06:52 PM
fuzzy
Mar 23, 2016 04:36 PM
Jay,
Mar 5, 2016 07:49 PM
M K
Feb 26, 2016 11:44 AM
dave1982rst
Dec 25, 2003 04:28 PM
