Ford Focus (All Models) This forum is for discussion of all things pertaining to the Ford Focus Range that doesnt belong in the seperate ST & RS sections..
Whats the difference between the Focus and Puma 1.4 zetec?
Old Aug 30, 2016 | 04:08 PM
~phoeny~'s Avatar
~phoeny~
Default Whats the difference between the Focus and Puma 1.4 zetec?
Hello
I drive a Ford Focus MK1 with a 1.4 Zetec engine. For some reason it only has 75HP. The original 1.4 from the Ford Puma has 90HP.
What do i have to change to get those 90HP?
so far i found that the intake manifold is bigger on the puma and the airbox has a better position. I guess there are differences in the ecu. i dont know about the throttlebody. is there anything else they changed?
Old Aug 30, 2016 | 05:04 PM
doga-ot's Avatar
doga-ot
On the focus 1.6 and fiesta 1.6 the focus has better gearing if that helps may be same for the 1.4
Old Aug 31, 2016 | 08:22 AM
~phoeny~'s Avatar
~phoeny~
How does the gearbox change hp? I thought that is an engine thing?
Old Aug 31, 2016 | 07:08 PM
martysmartie's Avatar
martysmartie
It doesn't, and yes it is.
They are the same engine, but it had to be detuned for emissions reasons.
As you say, I suspect the mapping to be different.
Martin
mdw84
Jul 17, 2016 09:58 PM
VEEDUBBED
Mar 26, 2016 09:46 PM
Danielbetty
Mar 14, 2016 10:55 AM
Vesty
Mar 4, 2016 05:43 PM
Rob Winstanley
Ford Focus Range
Mar 2, 2016 06:50 AM
